Hi Guys,
I’m tyring to execute a docker exec command via a shell command.
shell_command:
XY: bash /config/docker.sh "{{ value }}"
Within the sh file I want to execute a docker exec command to control a docker container which is running on Home Assistant.
The sh-File is successfully called but the docker command is not executed.
If I run the command directly via shell (protection off) it works.
So is it possible to deacitvate the protection mode to execute a docker command via an button or switch from a normal HA frontend?
