I want to execute 3 curl commands (maybe It is possible to do something else.
In my configuration.yaml,I merge :
shell_command:
sendon: curl http://192.168.1.145/sendon
sendoff: curl http://192.168.1.145/sendoff
puissance: curl http://192.168.1.145/?POWER=60
In my automation, I select Other–>call service
I write in it : shell_command.sendon
I save, homeassistant says : Error in describing action: undefined has no properties
What am I doing wrong ?
Thank you very much.
RESTART was the trick !!
