Hi, I am starting with HA and already managed to integrate my solar invertor (AWorks), but now I am trying to build my first automation based upon shell_command and can’t get it to work. What am I doing wrong? It seems the shell_command is not recognised in the configuration.yaml file.
I run HA OS 12.2 , core 2024.4.3 on a Raspberry PI5
my complete configuration.yaml:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
- platform: saj
host: 192.168.0.213
type: wifi
username: *my uid*
password: *my pw*
shell_command:
blynk_set_solar: 'curl https://lon1.blynk.cloud/external/api/update?token=*my blynk token* &V47=sensor.saj_aworks_current_power'
my complete automation.yaml:
- id: '1713372970113'
alias: solar2blynk
description: ''
- platform: state
entity_id:
- sensor.saj_aworks_current_power
condition: []
- service: shell_command.blynk_set_solar
data: {}
mode: single
When I look at the automation in the UI I get this error message:
Any suggestions highly appreciated.
