Shell_command newbie help
hi,
I am at my first shell_command attempt and I am a bit lost as my thingy does not work, nor it throws any error.
in configuration.yaml i have:
shell_command:
  write_to_msg: "echo {{msg}} >>/config/message.txt"
then I try running it via a script or via services under developer,
service: shell_command.write_to_msg
  msg: "abc"
The issue is that my file /config/message.txt does not get appended whith ‘abc’ nor does HA throw any error.
I am on haas OS
Any sugeestion what I am doing wrong/ where to look next?
I figured it out after 2 hours of forum reading and trial and error…
To make it work this is the change I came to:
shell_command:
  write_to_msg: /bin/bash -c "echo '{{ msg }}' >> /config/message.txt"
I think is the ’ ’ which were missing to surround the {{msg}}. I guess the bash interpreter did not know what to do with {{msg}}
