Shell_command not being executed by HA
Please advise what should be done for HA automation to execute the script from Shell_command?
My config.yaml:
shell_command:
  transmission_fin: bash /shell_scripts/transmission_fin.sh
My Automation:
alias: 'Transmission: AutoRemove Finished Torrent'
description: ''
  - platform: event
    event_type: transmission_downloaded_torrent
  - service: shell_command.transmission_fin
mode: single
Initially I thought HA has no access to System path above homeassistant directory, so I put a script in HA installation directory and created a subfolder shell_scripts there.
From terminal it works like a charm, but Automation does execute script.
Script is executable with rwxr-xr-x (0755).
Does it execute via the services tab in the interface?
It also may need to have shell_scripts whitelisted, or put it inside the www directory (which is inside the same directory as configuration.yaml is in)
No, it does not execute via Services too.
I tried to Whitelist this directory - did not work out.
Tried to put script into ‘www’ folder
shell_command:
  transmission_fin: bash /config/www/transmission_fin.sh
But it did not work too.
/local/transmission_fin.sh
Does not work either…
My host OS is Ubuntu. I tried full absolute paths, but it didn’t change a thing.
Is this the matter of script or paths? Any workaround?
maybe without the initial /
Also, what is in this script file?
The script file is here:
I tried
with no luck in the end…
How have you specified the SERVER? Could it be a name resolution issue?
By the way you shouldn’t need to use bash to run it, the script specifies which program to run it with.
#!/bin/bash
I tried even without ‘bash’, - no luck.
I think there should not be a problem with name resolution, because I explicitly point SERVER in script like this:
SERVER="192.168.0.3:9091 --auth mylogin:mypassword"
