This worked before as is, I think it got broken in one of the last versions but I’m not sure.
I use the value of an input_number
and pass it as int to shell_command
I’ve also enabled DEBUG traces to verify the data exists and it looks OK, however, the shell command is executed with the variable name and not with its value
switch:
my_switch:
friendly_name: MySwitch
value_template: "{{ is_state('switch.some_switch', 'on') }}"
turn_on:
service: shell_command.turn_on
data_template:
duration: "{{ states.input_number.my_input_number.state | int }}"
turn_off:
service: switch.turn_off
entity_id: switch.some_switch
and the relevant shell_command:
turn_on: 'python3 /config/control.py -m on -d {{ duration }}'
Logs:
home-assistant | 2018-10-06 19:10:32 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 140126865050704: Received {'type': 'call_service', 'domain': 'switch', 'service': 'turn_on', 'service_data': {'entity_id': 'switch.my_switch'}, 'id': 18}
home-assistant | 2018-10-06 19:10:32 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=switch, service=turn_on, service_data=entity_id=switch.my_switch, service_call_id=5f203ee32e29478cbf87045961929ee6>
home-assistant | 2018-10-06 19:10:32 INFO (MainThread) [homeassistant.helpers.script] Running script
home-assistant | 2018-10-06 19:10:32 INFO (MainThread) [homeassistant.helpers.script] Executing step call service
home-assistant | 2018-10-06 19:10:32 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=shell_command, service=turn_on, service_data=duration=30, service_call_id=af508fade98b407d88491ada1ac395bf>
home-assistant | 2018-10-06 19:10:32 DEBUG (MainThread) [homeassistant.components.shell_command] Stdout of command: `python3 /config/control.py -m on -d {{ duration }}`, return code: 1:
Notice the duration=30 that passed to the shell_command, but the stdout of the command containes the variable name {{ duration }}
and not the value.
I’ve tried putting quotes around the {{ duration }}
, without white spaces {{duration}}
and without the single quote on the entire command. nothing works.
