I am trying to run a php script through shell command. I have tested the php file and it runs well through the command line. Here is my code
# automations
automation:
- alias: test
platform: state
entity_id: input_boolean.test_btn
to: 'on'
- service: input_boolean.turn_off
entity_id: input_boolean.another_test
- service: shell_command.run_php
# shell command
shell_command:
run_php: 'php /var/www/test/test.php'
The automation runs well, other than not firing the shell command.
I have checked the home assistant log file and there are no reported errors. I have tried having the shell command with single quotes and without.
Any suggestions as to what I am doing wrong? Should I move the php file next to my configuration file? do I require some special permissions to run scripts from home assistant?
Thanks.
