If I delete the quoted string “Turning off Computer Cinema” from cmdline it doesn’t work either.
When I fire the shell command from the dev panel it does work and the pc shuts down.
Snippet of debug log when turned off switch.
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 140291954068784: Received {'type': 'call_service', 'domain': 'homeassistant', 'service': 'turn_off', 'service_data': {'entity_id': 'switch.computer_cinema'}, 'id': 11}
2018-04-23 19:43:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613568 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613600 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613520 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613504 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613584 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613344 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613488 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613536 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613408 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613312 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613328 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613456 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613296 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613616 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613632 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613440 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613648 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613664 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613680 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613696 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613712 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613728 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613744 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613760 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613776 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613792 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613808 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613824 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613840 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613856 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613872 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613888 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613904 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613920 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613936 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613952 FORWARDING <Event call_service[L]: domain=homeassistant, service=turn_off, service_data=entity_id=switch.computer_cinema, service_call_id=140292502390544-26>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613568 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613600 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613520 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613504 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613584 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613344 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613488 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613536 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613408 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613312 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613328 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613456 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613296 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613616 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613632 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613440 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613648 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613664 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613680 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613696 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613712 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613728 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613744 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613760 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613776 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613792 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613808 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613824 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613840 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613856 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613872 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613888 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613904 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613920 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613936 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613952 WRITING data: {"event_type": "call_service", "data": {"domain": "homeassistant", "service": "turn_off", "service_data": {"entity_id": "switch.computer_cinema"}, "service_call_id": "140292502390544-26"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.503354+00:00"}
2018-04-23 19:43:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=switch, service=turn_off, service_data=entity_id=['switch.computer_cinema'], service_call_id=140292502390544-27>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613568 FORWARDING <Event call_service[L]: domain=switch, service=turn_off, service_data=entity_id=['switch.computer_cinema'], service_call_id=140292502390544-27>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613600 FORWARDING <Event call_service[L]: domain=switch, service=turn_off, service_data=entity_id=['switch.computer_cinema'], service_call_id=140292502390544-27>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613520 FORWARDING <Event call_service[L]: domain=switch, service=turn_off, service_data=entity_id=['switch.computer_cinema'], service_call_id=140292502390544-27>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613504 FORWARDING <Event call_service[L]: domain=switch, service=turn_off, service_data=entity_id=['switch.computer_cinema'], service_call_id=140292502390544-27>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613584 FORWARDING <Event call_service[L]: domain=switch, service=turn_off, service_data=entity_id=['switch.computer_cinema'], service_call_id=140292502390544-27>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613344 FORWARDING <Event call_service[L]: domain=switch, service=turn_off, service_data=entity_id=['switch.computer_cinema'], service_call_id=140292502390544-27>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613488 FORWARDING <Event call_service[L]: domain=switch, service=turn_off, service_data=entity_id=['switch.computer_cinema'], service_call_id=140292502390544-27>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613536 FORWARDING <Event call_service[L]: domain=switch, service=turn_off, service_data=entity_id=['switch.computer_cinema'], service_call_id=140292502390544-27>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613408 FORWARDING <Event call_service[L]: domain=switch, service=turn_off, service_data=entity_id=['switch.computer_cinema'], service_call_id=140292502390544-27>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613312 FORWARDING <Event call_service[L]: domain=switch, service=turn_off, service_data=entity_id=['switch.computer_cinema'], service_call_id=140292502390544-27>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613328 FORWARDING <Event call_service[L]: domain=switch, service=turn_off, service_data=entity_id=['switch.computer_cinema'], service_call_id=140292502390544-27>
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613456 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613744 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613760 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613776 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613792 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613808 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613824 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613840 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613856 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613872 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613888 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613904 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613920 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613936 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 DEBUG (MainThread) [homeassistant.components.api] STREAM 140291988613952 WRITING data: {"event_type": "call_service", "data": {"domain": "switch", "service": "turn_off", "service_data": {"entity_id": ["switch.computer_cinema"]}, "service_call_id": "140292502390544-27"}, "origin": "LOCAL", "time_fired": "2018-04-23T17:43:13.529681+00:00"}
2018-04-23 19:43:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140292502390544-27>
140291954068784: Sending {'id': 11, 'type': 'result', 'success': True, 'result': None}
