Shell command parsing of variable to append in txt file doesn't work
After spending 2 nights of trying - what feels like - a thousand different combinations and reading just as much different websites, I just can’t get the following to work.
My attempt is to append the content of a variable to a text file.
When I set up this:
shell_command:
  shell1: "echo this is a first reminder  > ~/.homeassistant/tts/reminders.txt"
  shell2: "echo this is a second reminder  >> ~/.homeassistant/tts/reminders.txt"
And then use it in the action section of my automation like this:
  - service: shell_command.shell1
  - service: shell_command.shell2
This all works. The file gets created with the 1st line and the 2nd line gets added.
I differentiate between > and >> because sometimes I need the system to start with a fresh empty file, sometimes it needs to append.
However, as soon as I try the same thing with variables, it doesn’t work anymore.
What I want is the attribute of an entity to be added.
shell_command:
  shell1: "echo {{ states.calendar.google_reminder.attributes.message }} > ~/.homeassistant/tts/reminders.txt"
  shell2: "echo {{ states.calendar.google_reminder.attributes.message }} >> ~/.homeassistant/tts/reminders.txt"
In the automation, I tried calling the shell_command both through service: and through service_template: but no luck, the file doesn’t get created and nothing gets added.
I then started experimenting:
shell_command:
      shell1: "echo '{{ states.calendar.google_reminder.attributes.message }}' > ~/.homeassistant/tts/reminders.txt"
      shell2: 'echo "{{ states.calendar.google_reminder.attributes.message }}" >> ~/.homeassistant/tts/reminders.txt'
      shell3: echo '{{ states.calendar.google_reminder.attributes.message }} >> ~/.homeassistant/tts/reminders.txt
      shell4: echo "{{ states.calendar.google_reminder.attributes.message }}" >> ~/.homeassistant/tts/reminders.txt
However, all with the same result (none). I don’t think it is the entity_id that causes the issue because when I try to send the same variable to Telegram, it works fine:
  - service: notify.telegram
    data_template:
      message: "{{ states.calendar.google_reminder.attributes.message }}"
This send very nicely the content to my Telegram Bot.
I also tried by first creating template sensors and then having the shell_command call the template sensor, however without success neither…
I looked in the logging but couldn’t find anything neither…
What could this be ?
I have some shell commands that accept arguments, but I haven’t set one that pulls a value from a template. Here’s an example I have of one shell_command that passes arguments to a script that talks to another device on my network:
shell_command:
  ievent: bash /home/pi/scripts/ievent.sh {{command}}
Then from an automation:
- service: shell_command.ievent
    command: rgb-on
So the net is that when that automation triggers, the command line sees
bash /home/pi/scripts/ievent.sh rgb-on
I wonder if you could do something similar. Set up the shell command to be
shell_command:
  reminder: echo {{reminder_text}} >> ~/.homeassistant/tts/reminders.txt"
Then use that from any automation/script/etc where you wanted to, with:
- service: shell_command.reminder
  data_template:
    reminder_text: '{{ states.calendar.google_reminder.attributes.message }}'
Nope, doesn’t work :(.
Only when the shell command doesn’t contain any variable, it works. But that’s useless :frowning:
Looking at this, I’m wondering if you’ve just got a string-quoting issue. Have you tried putting quotes around “reminder_text”?
shell_command:
  reminder: echo "{{reminder_text}}" >> ~/.homeassistant/tts/reminders.txt"
You’ve tested this from the command line (outside of HASS), right?
Yes I did. I now moved on to writing a bash script to try to get to it:
new_reminder.sh:
#!/bin/bash echo $1 > ~/.homeassistant/tts/reminders.txt
add_reminder.sh:
#!/bin/bash echo $1 >> ~/.homeassistant/tts/reminders.txt
The shell commands:
shell_command:
  new_reminder_file: bash CORRECT_PATH/scripts/new_reminder.sh "{{ text }}"
  add_reminder_file: bash CORRECT_PATH/scripts/add_reminder.sh " {{ text }}"
Also in the data_template I use quotes.
When trying via the command line to send something to the scripts, it works.
Did you ever get this working?
An old thread but this tripped me up as well…
Seems that the command_shell component executes the command in different ways dependent on whether the command contains templates/variables. If templates are detected then the component executes the command by calling create_subprocess_exec() whereas without templates it uses create_subprocess_shell() instead. The difference is that the former doesn’t process the file redirection whereas the later does. If using templates then you can avoid having to create a stand-alone shell script by passing the desired command in quotes to /bin/bash -c as follows:
shell_command:
    shell1: /bin/bash -c "echo '{{ states.calendar.google.attributes.message }}' > ~/.homeassistant/output.txt"
Omg, thank you!!!
I literally spent the past 6 hours doing intense googling, restarting the server and rewriting the script, trying to figure out this problem. I signed up to the forum so I can write this response.
THANK YOU!!!
Same as above. This fixed a problem of sending data to serial ports.
I owe you a beer.
thank you! I just ran into this problem and found your solution also. Cheers.
