Shell command python not working
Hi, i need to pass value into the python script.
shell_command.dosomething works with the value 3.
But it doesn’t work if the value is from the service data: shell_command.dosomething2
Any one have any idea why. Please advise. Thank you!
shell_command:
  dosomething: python \.homeassistant\python\dosomething.py 3
  dosomething2: python \.homeassistant\python\dosomething.py {{ states.input_slider.ac_temperature.state | int }}
automation:
  - alias: run_set_ac
      platform: state
      entity_id: input_slider.ac_temperature
      service: shell_command.dosomething2
input_slider:
  ac_temperature:
    initial: 1
    min: 1
    max: 30
    step: 1
Hi @Inverser, have you tried it with quotes?
dosomething2: 'python \.homeassistant\python\dosomething.py "{{ states.input_slider.ac_temperature.state }}"'
I think you don`t need to convert to int.
I have this working:
record_sensors:
  python /home/homeassistant/.homeassistant/includes/shell_scripts/sensors2file.py {{sensor01}} {{sensor02}} {{sensor03}} {{sensor04}}
and the relevant part in automations.yaml file:
- id: id015
  alias: 'Record sensors to local file'
    platform: time
    minutes: '/15'
    seconds: 00
    - service: shell_command.record_sensors
      data_template:
        sensor01: '{{states.sensor.dark_sky_temperature.state | float}}'
        sensor02: '{{states.sensor.temperature_sensor_1_1.state | float}}'
        sensor03: '{{states.sensor.sonoff_01_power.state | float}}'
        sensor04: '{{states.binary_sensor.door_sensor_2_0.attributes.battery_level | float}}'
HOWEVER, if the solution posted by @VDRainer works, it is definitely much simpler.
Good luck!
Hi VDRainer, thanks for the reply.
I tried what you suggested but still doesn’t work…
looks like the path is wrong to me :stuck_out_tongue:if on pi it should be something like…
./home/pi/homeassistant/.homeassistant/python/dosomething.py ?
if in windoze again you will need the full path.
you also may have to use the full path to python
What is returned when you copy the template in Developer Tools/Templates?
Have you already tried it with convert to int?
Maybe i was wrong with this.
Or maybe try the solution of @timseebeck.
For me, this works:
set_hyperion_effect: 'scripts/hyperion_effect.sh "{{ states.input_select.hyperion_effect.state }}"'
Bash an input_select, but that should be the same.
Got it to work. Just change to forward slash rather than using backslash…
Thanks for your help!
Thanks for the help!
Didn’t notice I’m using the wrong slash…
You are right! Thank you!
