Shell command return code 255
My shell command
hdmi_off: ssh [email protected] /home/pi/rpi-hdmi.sh off
Is working fine in Putty but when i call the service in HA i get following error in the log:
ERROR (MainThread) [homeassistant.components.shell_command] Error running command: ssh [email protected] /home/pi/rpi-hdmi.sh off, return code: 255
NoneType: None
What could it be?
Hi, I’m having the same problem, could you find the solution?
Thank you
having the same issue with ssh remote command, did you find a solution for this??
Same here. I have a simple command to sleep my iMac which runs fine from hassio shell but not from UI toggle. I think it has to do with Hass being in docker but I can’t get into the container’s shell either as the containers aren’t actually listed in Portainer.
Any tips?
create a key with ssh-keygen and then copy ssh-copy-id [email protected] to the target system using ssh-copy-id.
After that you can log in to the console without a password on the foreign system and you can do that in Home Assistant commands scripts via SSH
THIS MIGHT NOT BE BEST SECURITY PRACTICE!
But i got it working like this:
command: "/usr/bin/ssh -i /config/ssh/id_rsa -o UserKnownHostsFile=/config/ssh/known_hosts user@host 'remote_command'"
after i copied my id_rsa and known_hosts files in the locations in the config folder, so homeassistant has access to it.
Now i am not too familiar with permission stuff. So if anyone more qualified could comment further on the security implications of this, i’d appreciate it.
