malosaa
(Hector)
July 14, 2023, 8:50am
1
How to do this,
the reason why i’m trying is that the REST platform doesn’t support variables in the payload and that’s really annoying
I’m using payed version of 17track and created a command that registers the package number, that works really great.
However i need to use this code to return the data.
but how to return the data when executed ??
shell_command:
track_17_details: ‘curl -X POST --header “17token: MYAPI” --header “Content-Type: application/json” --data “[ { “number”: “{{ number }}”, “carrier”: “{{carrier}}” } ]” https://api.17track.net/track/v2/gettrackinfo ’
In the rest api it does return when manually input the trackingcode, but like said before variables dont work, and i cant find a way arround it… only using shell_command…
SO what i want is that the shellcommand returns the data in a entity like rest does, is that possible ?
I do it by putting the command in a bash script and then (in the script) calling the HA API. Here is an example :
The shell command:
shell_command:
get_aircraft_reg: bash /config/scripts/aircraft_reg.sh {{states('sensor.low_level_registration')}}
The bash script:
#!/bin/sh
echo $1
curl --request GET --url https://hexdb.io/api/v1/aircraft/$1 > /tmp/aircraft_reg && sed -i 's/Registration/state/g' /tmp/aircraft_reg | curl -X POST -H 'Authorization: Bearer Your Token' -H 'Content-Type: application/json' -d @/tmp/aircraft_reg http://192.168.1.25:8123/api/states/sensor.aircraft_reg
I hope this gives you an idea of what you can do
Alternatively, you can use a rest sensor like this :
rest:
- resource_template: https://api.spotify.com/v1/search?q={{ states('sensor.media_title_office')|default('')|replace(' ','%20')|replace("'",'%27') |replace(':','%3A') }}%2C%20{{ states('sensor.media_artist_office') |default('')|replace(' ','%20')|replace("'",'%27')|replace(':','%3A')|regex_replace('\([0-9]+\)')}}&type=track%2Cartist&limit=1
headers:
Authorization: Bearer {{ state_attr("sensor.spotify_token","access_token") }}
Accept: application/json
scan_interval: 1800
- name: spotify_url_rest
unique_id: sur
value_template: 'OK'
json_attributes_path: "$.tracks.items[0].external_urls"
json_attributes:
- spotify
- name: spotify_track_rest
unique_id: str
json_attributes_path: "$.tracks.items[0]"
json_attributes:
- name
- name: spotify_artist_rest
unique_id: sar
json_attributes_path: "$.tracks.items[0].artists[0]"
json_attributes:
- name
- name: spotify_album_rest
unique_id: sal
json_attributes_path: "$.tracks.items[0].album"
json_attributes:
- name
Set the scan interval to something like 3600 and then just call the refresh like this :
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- service: homeassistant.update_entity
data: {}
entity_id:
- sensor.spotify_artist_rest
- sensor.spotify_track_rest_3
- sensor.spotify_url_rest
- sensor.spotify_album_rest
malosaa
(Hector)
July 14, 2023, 9:38am
4
many many thanks @Neil_Brownlee
as i want to keep it simple, how can i modify the rest sensor like you did ?
i have something like this:
but don’t know how to get arround the payload.
If i manually fill in the number and carrier this works, however no variables.
rest:
authentication: basic
scan_interval: 86400
resource: https://api.17track.net/track/v2/register
method: POST
headers:
content-type: application/json
17token: MYAPI
payload: |
“number”: “{{ states(‘input.track_17_carrier_number’) }}”,
“carrier”: “{{ states(‘sensor.track_17_carrier_mapping’) }}”
value_template: “{{ value_json }}”
i also did try an other approach but im stuck.
i did use the command_line platform to capture the output.
platform: command_line
command: “bash -c ‘{{ shell_command.get_tracking_details }}’”
however this throws me errors.
With rest, you need to use :
resource_template:
Although looking at it, maybe that won’t help if you can’t send the variables in the URL. I am sure that’s why I went with the bash scripts in the end for some of my calls. There may be better ways, but until you can use templates in some of the calls you are sort of banjaxxed.
malosaa
(Hector)
July 14, 2023, 9:46am
6
ok,
and using this way ?
i tried but getting errors.
as it should work this way… just sad the devs do not allow variables in the payload…
No variables allowed in the command: sadly.
malosaa
(Hector)
July 14, 2023, 10:01am
8
its just weird, in shell_command: i can use the variables but not retrieve the data…
well i’m stuck now lol
malosaa
(Hector)
July 14, 2023, 10:02am
9
however this dude did manage to do it, but i need to find out how
jq doesnt seem to care. Good for you
- platform: command_line
name:
command: curl -s 'http://SMART_METER_IP/inst.json' | jq .type_imp_0
scan_interval: 60
you can do a lot with the command sensor - I query my local transporter wit it.
# https://www.data.gv.at/katalog/dataset/add66f20-d033-4eee-b9a0-47019828e698
# data.wien.gv.at' Lizenz (CC BY 3.0 AT)
# the comand is as following:
# curl -s 'http://www.wienerlinien.at/ogd_realtime/monitor?rbl=******STOP-HERE******&send…
malosaa
(Hector)
July 14, 2023, 1:58pm
10
ive done it, i found a way arround how to do it when rest doesnt support variables… hehe
You need to share you solution to assist others
malosaa
(Hector)
July 14, 2023, 3:20pm
12
i forget, here is my solution to this problem
i created this to run the same command as i did in rest with command_line and it’s basically the same except u can use variables in the payload.
command_line:
scan_interval: 9000
json_attributes:
- data
command: >-
curl -X POST --header “17token: MYTOKEN” --header “Content-Type: application/json” --data “[ { “number”: “{{ states(‘input_text.17_track_code_input’) }}”, “carrier”: “{{ states(‘input_text.17_track_carried_input’) }}” } ]” https://api.17track.net/track/v2/gettrackinfo
value_template: “{{ value_json.data.tracking_result }}”
