When I run this command, nothing happens. Nothing shows up in the log (even on INFO level). Yet when I remove the template with a random number or string, the message gets sent.
Thanks! I implemented the script. The script works without templating. When I added the template though, things stopped working. Now I am getting an error:
2019-12-13 11:13:09 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1821160752] [Errno 8] Exec format error: '/config/forward_temperature.sh'
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 133, in handle_call_service
connection.context(msg),
File "/usr/src/homeassistant/homeassistant/core.py", line 1235, in async_call
await asyncio.shield(self._execute_service(handler, service_call))
File "/usr/src/homeassistant/homeassistant/core.py", line 1260, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/shell_command/__init__.py", line 78, in async_service_handler
process = await create_process
File "/usr/local/lib/python3.7/asyncio/subprocess.py", line 217, in create_subprocess_exec
stderr=stderr, **kwds)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 1529, in subprocess_exec
bufsize, **kwargs)
File "/usr/local/lib/python3.7/asyncio/unix_events.py", line 190, in _make_subprocess_transport
**kwargs)
File "/usr/local/lib/python3.7/asyncio/base_subprocess.py", line 37, in __init__
stderr=stderr, bufsize=bufsize, **kwargs)
File "/usr/local/lib/python3.7/asyncio/unix_events.py", line 775, in _start
universal_newlines=False, bufsize=bufsize, **kwargs)
File "/usr/local/lib/python3.7/subprocess.py", line 800, in __init__
restore_signals, start_new_session)
File "/usr/local/lib/python3.7/subprocess.py", line 1551, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
OSError: [Errno 8] Exec format error: '/config/forward_temperature.sh'
I belive you that this works no worries but your command has no pipe | in it, but the one from OP has.
From the docs:
The commands can be dynamic, using templates to insert values for arguments. When using templates, shell_command runs in a more secure environment which doesn’t allow any shell helpers like automatically expanding the home dir ~ or using pipe symbols to run multiple commands. Similarly, only content after the first space can be generated by a template. This means the command name itself cannot be generated by a template, but it must be literally provided.
