I’m trying to automate the upload of my snapshot files to a NAS, I use this command (and it works correctly in terminal):
find /backup -type f -exec curl -u admin:password -T {} ftp://192.168.1.110/Hass.io/ \;
I then created a Shell Command with the same command:
shell_command:
backup_snap_ftp: 'find /backup -type f -exec curl -u admin:password -T {} ftp://192.168.1.110/Hass.io/ \;'
When I call the shell command it fails.
If I call the same shell command but pointing at /config instead of /backup, using some test file, it works correctly.
/backup and /config have the same permissions:
drwxr-xr-x
the files under each folder have the same permissions.
For test I created a shell command that touches a file, under config it works, under backup does not. It seems clear that is permission related, but I can not really figure where is the problem.
Any help?
