Shell_command - what happens with the process
I can run shell commands directly from Home Assistant Core on a Mac. How can I monitor or at least stop it?
The idea is that I want to run a process for a certain time and then quit it.
You cannot run long-running processes from a shell commands. It will timeout and be killed within 10sec (iirc).
Your plan would be to launch the process in the background with the shell command, then have a process-specific way to monitor it with other sensors.
That makes totally sense!
10 seconds are not enough for me. So what is the way to do this without opening dozens of terminal windows?
