I have a problem with a shell command
I have two shell commands in configuration.yaml:
shell_command:
upload_warmteprod:
python3 /config/python_scripts/upload2.py {{ states.luxtronik.warmteprod.state | float }} >
/config/python_scripts/test_upload.json
get_gateway_json:
python3 /config/python_scripts/gateway.py >
/config/python_scripts/gateway.json
The second shell command (get_gateway_json) works fine.
But the first shell command (upload_warmteprod) doesn’t work.
When i replace "{{ states.luxtronik.warmteprod.state | float }} " with a number (for instance 123.4) it works fine. So the problem resides in the template.
When I evaluates {{ states.luxtronik.warmteprod.state | float }} it also works fine.
What am I doing wrong?
Thanxs in advance.
