I will remove from the script the battery sensor for H&T with the external power supply.
Questionā¦ I have problem that I added resource of Shellies Discovery to lovelace as itās seen on instruction:
/hacsfiles/ha-shellies-discovery/shellies-discovery.zip
module
But the problem is that:
## Podrobnosti dnevnika (ERROR)
Logger: hacs
Source: custom_components/hacs/http.py:76
First occurred: 21:51:41 (8 occurrences)
Last logged: 23:50:06
Tried to serve up '/config/www/community/ha-shellies-discovery/shellies-discovery.zip' but it does not exist
So, do I need to delete this resource, because I do not have any such kind of .ZIP fileā¦ But Shellies Discovery is working just normalā¦
I figer it our, that it was doubled - already have all set in configuration fileā¦ I just deleted resourcesā¦ but then in HACS is marked as redā¦ so where do I find this ā.ZIPā file?
Please read the open post because youāre doing very strange things.
And what would that be?
In instructions there is:
Regarding configurationā¦ I was mistake - configuration is for ShellyForHASSā¦ so where do I find this .ZIP file so that I can add it so that error would be gone?
Shellies Discovery was installed via HACSā¦
And resources as in instructionā¦
Shellies Discovery
is a python_script
not a JavaScript module for frontend. How did you install it in this way???
I just added via HACSā¦ Then I added folder and file for python ā¦ make 2 restarts of HA and thatās itā¦ so script is working normaly, just producing notification āerrorā in log fileā¦
Do you have Shellies Discovery
in python script
category in HACS?
If HACS correctly installs the script, you donāt have to add any folder or file.
So, how to add it here?
Itās there by default https://hacs.xyz/docs/default_repositories#python-scripts Your HACS configuration is broken somehow.
I will try to delete shellies and clear cache of HACS and try againā¦ thank you for your helpā¦
Thank youā¦
after strugling how to remove and after editing āhacs.repositoriesā I could install via āpython menu in HACSā.
Now it looks like:
So thank you for your helpā¦
Hi Gyys
Im very new to home assistant and am trying to setup an energy dashboard, I am using a shelly em and two clamp meters.
I am using your script to discover my device which is working great thank you. Im then pulling the data into influxDB currently the data only gets recorded when there is a change in the value is there a way to get it to update every minute even if there is no change in the value?
Thank you in advance for any help
Craig
I think this is a question related to influxDB. Iām sorry, I canāt help you.
no probs mate thank you anyways
@Bieniu I am not sure it is only related to influxdb. I think it is also related to the force_update variable of MQTT sensors. It seems to be useful to have meaningful histories.
I think it will be a nice addition to be able to set this variable to true as an extra argument to shelly sensors.
Yes, youāre right. I will add this as an option.
Sorry Bieniu Maciek, I updated to the latest version but I continue to see the battery on the H&T. I added the shellyht-fxxxxx: ac_power action on the automations, but nothing does not change. Am I wrong? Itās just an aesthetic thing, everything works perfectly.
Could you enable debug
for homeassistant.components.python_script
and post the log here?
