Shellies Discovery is a script for python_script
component. This component imposes huge restrictions, therefore only config
topics can be removed from the broker by the script.
@truglodite Maybe we should take this into another thread, as it is more a mqtt-remove problem in general, than a shelly-discovery problem.
I found an older thread, with a guide to remove mqtt entries, here it is: [Guide] How to remove MQTT entity from Zigbee2mqtt, Mosquitto broker and Home Assisntant
I agree this isnât really related to the shellies discovery script, and actually it isnât related to mqtt removal either (I already read those threads and knew how to do it). If anything, this would be better in a shelly dimmer thread, due to the settings not sticking until after reboot problem that resulted in issues with the usual mqtt removal methods.
Hi.
After the last update I kepp getting this in the log.
Can you tell whats wrong or do I need to activate debug logger ?
Exception in discovery_callback when dispatching 'mqtt_discovery_updated_('binary_sensor', 'shellyswitch25-*******-overtemperature')': ({'name': 'Shelly2.5 ***** Overtemperature', 'state_topic': 'shellies/shellyswitch25-********/overtemperature', 'payload_on': '1', 'payload_off': '0', 'availability_topic': 'shellies/shellyswitch25-*********/online', 'payload_available': 'true', 'payload_not_available': 'false', 'device_class': 'heat', 'unique_id': 'shellyswitch25-**********-overtemperature', 'qos': '0', 'device': {'identifiers': ['******'], 'name': 'Shelly2.5 *******', 'model': 'Shelly2.5', 'sw_version': '20200309-104051/v1.6.0@43056d58', 'manufacturer': 'Allterco Robotics'}, 'platform': 'mqtt'},)
File "/usr/src/homeassistant/homeassistant/components/mqtt/__init__.py", line 1186, in discovery_callback
payload.pop(ATTR_DISCOVERY_HASH)
KeyError: 'discovery_hash'
It seems that this error isnât related to Shellies Discovery. You can turn on debug and post the log here. Maybe I will find something that help you.
When I run the script it adds my shelly 2.5 as a relay. How can i force the script to add my shelly 2.5 as a cover?
The Shelly1PM and Dimmer work perfectly with this script
Please read the docs https://github.com/bieniu/ha-shellies-discovery/blob/master/README.md#arguments-for-shelly25
Iâm new to HA and MQTT and I have some problems with shelly working via MQTT.
First problem:
Discovery script donât work. I make everything as described in instructions.
- Installed shellies_discovery.py to python_scripts folder and add python_script: to configuration.yaml.
- Add minimal configuration to automation.yaml
- Configure shelly to mqtt:
- Configure mosquitto broker:
In mosquitto broker LOG I can see that shelly is comunicating with broker:
â1586091984: New connection from 192.168.1.61 on port 1883.
1586091984: New client connected from 192.168.1.61 as shelly1-B9FACE (p2, c1, k60).â
- Restart several times and there is NO shellies in integration.
Second problem:
I also tried manual adding shellies with code:
- platform: mqtt
name: "Kitchen Light mqtt"
state_topic: "shellies/shelly1-B9FACE/relay/0"
command_topic: "shellies/shelly1-B9FACE/relay/0/command"
payload_on: "ON"
payload_off: "OFF"
state_on: "ON"
state_off: "OFF"
retain: false
optimistic: false
After that I can add a button, but it is always OFF. Even if I press ON via button or via HA the button goes automaticaly back to OFF. The light didnât turn ON.
With REST api everything work, but I want to MQTT start working.
What I am doing wrong?
Thanks.
Turn on debug
for the python_script
component and show me a log.
Please forgive me if this has been covered before. I tried to search but was not successful in finding answers.
I am using this amazing script and it is discovering all my devices. I am using a Shelly 1 for my garage doors and I have attached reed switches to them in hopes of detecting open/close states.
My confusion is how to use the information this script provides to create a card to display the open/close state. Any help would be appreciated.
Thank you
There is no information about running the Shellies Discovery
script in your log.
Does Shelly1 support reed switches at all?
They do. Here is a url that has a guide that I was following in case it may help. https://www.sweharris.org/post/2019-05-19-garage/
Nie znaĹem tego rozwiÄ zania. Nie znam Ĺźadnej karty frontendowej, ktĂłra pokazywaĹaby takÄ konfiguracjÄ.
I donât know what is wrong?
I put this to configuration.yaml:
logger:
logs:
homeassistant.components.python_script: debug
python_script:
Now I run both automation manualy in automation and there is a log file: https://we.tl/t-VlBVnNnwrc
Thx
David
Still nothing. You canât run shellies_discovery
script manually. Change logger default level to warning
because the log is totally unreadable! Look at the troubleshooting checklist. Check if automations are turned on. Is there a service mqtt.publish
in the developer options?
Changed loger default setings to warning and now it is only this in LOG file:
2020-04-06 16:02:19 WARNING (MainThread) [homeassistant.components.mqtt] Data in your configuration entry is going to override your configuration.yaml: {âbrokerâ: âcore-mosquittoâ, âdiscoveryâ: False, âpasswordâ: ârei5Ieg0QuaeRien2pe1ThooBei5woh2oolo9phai0teag4Jie3Aethaetheefieâ, âportâ: 1883, âprotocolâ: â3.1.1â, âusernameâ: âhomeassistantâ}
2020-04-06 16:02:30 WARNING (MainThread) [homeassistant.components.switch] Setup of switch platform rest is taking over 10 seconds.
2020-04-06 16:02:30 ERROR (MainThread) [homeassistant.components.rest.switch] No route to resource/endpoint: http://192.168.86.51/relay/1
I checked everything in troubleshooting list and everything is as writen.
Automation in ON at both Shellies Anounce and Shellies discovery.
mqtt.publish is in developer options.
In LOG file I see this ââbrokerâ: âcore-mosquittoâ, âdiscoveryâ: Falseâ. Is this a problem?
I have this configuration and discovery is included:
discovery:
mqtt:
broker: 192.168.1.138
port: 1883
discovery: true
discovery_prefix: homeassistant
logger:
default: warning
logs:
Yes, discovery is required.
Continuing the discussion from Shellies Discovery Script:
Is it possible to change on the HT battery with external power supply? I have two USB powered ones but I see 100% grace
