Shellies Discovery Script
You can’t add availability_template to an existing sensor, you have to create a new one (template sensor).
Can you help me with a sample code of a new template sensor pls?
It would help me a lot…
Thank you
If you do, I will try and share the results with you. But you may have to help because I’m a beginner here.
Can someone help me: get this error on startup`
Error executing script: expire_after value None is not an integer, check script configuration Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/python_script/__init__.py", line 222, in execute exec(compiled.code, restricted_globals) File "shellies_discovery.py", line 2660, in <module> TypeError: expire_after value None is not an integer, check script configuration
Show me configuration of the script.
I have problem that Shelly Valve is not discovered by the script… probably not problem in the script but somewhere in configuration…
Can you please share me mqtt sensor configuration for shelly valve (TRV) so that I try to configure in old fashion way…
Thank you…
I mean to add mqtt sensors manually as I am used to do with Tasmota…
I get the same error. Just installed the script and the two default automations like discribed in the docs.
And I have another issue with hacs. I am able to update using HACS but when open the automations tab I even cant find the discovery script and it is not even listed.
Maybe anyone knows this issue. Is there away to force hacs clearing cache and scan for installed components again? The python_script integration is enabled for a long time in my configuration.
Please post a debug log for python_script component.
Which sensor?
If you want I can help with Shellies Discovery, post here a debug log for python_script component.
I set this in the configuration-file:
logger:
  default: warning
  logs:
    homeassistant.components.python_script: debug
After restart, I here is the log. I get an info message and this:
2022-01-12 08:06:30 ERROR (SyncWorker_5) [homeassistant.components.python_script.shellies_discovery.py] Error executing script: host value None is not valid, update shellies_discovery automation
File "shellies_discovery.py", line 1207, in <module>
ValueError: host value None is not valid, update shellies_discovery automation
Discovery automation
- id: 'shellies_discovery'
  alias: 'Shellies Discovery'
  mode: queued
  max: 999
    platform: mqtt
    topic: shellies/announce
    service: python_script.shellies_discovery
      id: '{{ trigger.payload_json.id }}'
      mac: '{{ trigger.payload_json.mac }}'
      fw_ver: '{{ trigger.payload_json.fw_ver }}'
      model: '{{ trigger.payload_json.model }}'
      mode: '{{ trigger.payload_json.mode | default }}'
      host: '{{ trigger.payload_json.ip }}'
So, I renew python script (re-download it from HACS).
I set:
logger:
  default: fatal
  logs:
    homeassistant.components.automation: info
I also set mqtt discovery and prefix:
  broker: 192.168.XX.XX
  port: 1883
  username: XXXX
  password: XXXX
  discovery: true
  discovery_prefix: homeassistant
I also renew discovery script and announce in automation…
- id: '010'
  alias: 'Shellies Announce'
    - platform: homeassistant
      event: start
    - platform: time_pattern
      hours: "/1"  # Modifying this if you are using Shelly Motion can drain your device's battery quickly.
    service: mqtt.publish
      topic: shellies/command
      payload: announce
  mode: single
- id: '011'
  mode: queued
  max: 999
    platform: mqtt
  mode: single
In MQTT HA finds new “already” added device… so discovery is working… but I do not get Shelly Valve (I have 6 devices), every valve has name shellytrv-DIFFERENT_NAME…
So, I’m a little lost…
Which logs do you need to find what is happening… Because in “home-assistant.log” I do not get any info of valve…
Also… script do detect shelly rgbw2… so it’s working… it seems that something is wrong regarding valve detection…
Show me please the log.
And where is the log? :slight_smile:
2022-01-12 18:00:00 WARNING (MainThread) [homeassistant.components.automation.shellies_discovery] Shellies Discovery: Already running
2022-01-12 18:00:00 INFO (SyncWorker_0) [homeassistant.components.python_script] Executing shellies_discovery.py: {'id': 'shellyrgbw2-hodnik', 'mac': 'XXXXXXXX', 'fw_ver': '20211109-130054/v1.11.7-g682a0db', 'model': 'SHRGBW2', 'mode': 'color', 'host': '192.168.XXX.XXX', 'discovery_prefix': 'homeassistant', 'qos': 2}
2022-01-12 18:00:00 DEBUG (SyncWorker_0) [homeassistant.components.python_script.shellies_discovery.py] id: shellyrgbw2-hodnik, mac: XXXXXXXX, fw_ver: 20211109-130054/v1.11.7-g682a0db, model: SHRGBW2
2022-01-12 18:00:00 DEBUG (SyncWorker_0) [homeassistant.components.python_script.shellies_discovery.py] {'topic': 'homeassistant/button/shellyrgbw2-hodnik-update_firmware/config', 'payload': '{"name": "Shelly RGBW2 hodnik Update Firmware", "cmd_t": "~command", "payload_press": "update_fw", "en": "true", "uniq_id": "shellyrgbw2-hodnik-update_firmware", "qos": 2, "avty_t": "~online", "pl_avail": "true", "pl_not_avail": "false", "dev": {"cns": [["mac", "XXXXXXXX"]], "name": "Shelly RGBW2 hodnik", "mdl": "Shelly RGBW2", "sw": "20211109-130054/v1.11.7-g682a0db", "mf": "Allterco Robotics", "cu": "http://192.168.XXX.XXX/"}, "~": "shellies/shellyrgbw2-hodnik/", "entity_category": "config", "dev_cla": "update"}', 'retain': True, 'qos': 0}
This?
No single line regarding Shelly TRV (valve)…
PS. I reduced sensitive inf. with XXX
Don’t know how this will help you? :roll_eyes:
- id: shellies_announce
  alias: Shellies Announce
    event: start
    hours: /3
  - service: mqtt.publish
      payload: announce
  mode: single
- id: shellies_discovery
  alias: Shellies Discovery
  mode: queued
  max: 999
    platform: mqtt
      qos: 0
      shellyplug-s-DBED15:
        relay-0: switch
        force_update_sensors: true
      shellyplug-s-9A34D0:
        relay-0: switch
      shellyplug-s-9A3DA7:
        relay-0: switch
      shellyplug-s-B52B86:
        relay-0: switch
      shellyswitch25-E0980695937D:
        roller-0-name: ROL_LIVING_TUIN
        roller-0-class: shutter
      shellyswitch25-40F5202A441B:
        roller-0-name: ROL_LIVING_ZIJKANT
      shellyswitch25-40F520002101:
        roller-0-name: ROL_LIVING_STRAAT
      shellyswitch25-40F5202A9946:
        roller-0-name: ROL_KEUKEN
      shellyswitch25-40F5202A9639:
        roller-0-name: ROL_ACHTERDEUR
      shellyswitch25-40F520018AD2:
        roller-0-name: ROL_BADKAMER
      shelly1-40F5200110A5:
        relay-0: switch
        relay-0-name: L_TUIN
      shelly1-40F520003F14:
        relay-0: switch
        relay-0-name: L_INKOM
      shelly1-40F5200045E7:
        relay-0: switch
        relay-0-name: L_OVERLOOP
      shelly1-F4CFA2E5EA4B:
        relay-0: switch
        relay-0-name: L_WC_GLV
      shellyswitch25-40F5202A97A2:
        relay-0: switch
        relay-0-name: L_LIVING_TAFEL1
        relay-1: switch
        relay-1-name: L_LIVING_TAFEL2
      shellyswitch25-40F5202A44B4:
        relay-0: switch
        relay-0-name: L_BERGING
        relay-1: switch
        relay-1-name: L_KEUKEN
      shellyswitch25-3C6105E55F21:
        relay-0: switch
        relay-0-name: L_TUIN1
        relay-1: switch
        relay-1-name: L_TUIN2
      shelly1-40F52000E397:
        relay-0: switch
        relay-0-name: BWM_1_INKOM
      shelly1-40F520000EFE:
        relay-0: switch
        relay-0-name: BWM_2_KEUKEN
      shelly1-40F5200103D3:
        relay-0: switch
        relay-0-name: BWM_3_BERGING
      shelly1-F4CFA2ECE8FD:
        relay-0: switch
        relay-0-name: BWM_4_OVERLOOP
      shelly1-F4CFA2E5E63B:
        relay-0: switch
        relay-0-name: BRANDDET_BERGING
      shelly1-E8DB84D23A8D:
        relay-0: switch
        relay-0-name: BRANDDET_OVERLOOP
      shelly1-40F520008262:
        relay-0: switch
        relay-0-name: SIRENE
      shelly1-F4CFA2ECE900:
        relay-0: switch
        relay-0-name: CV-KETEL
      shellydimmer2-F4CFA2E1041B:
        light-0-name: L_LIVING_ZETEL
      shellydimmer2-40F520014879:
        light-0-name: L_SLPK1
      shellymotionsensor-60A423992EAC:
      shellymotionsensor-60A42399345E:
      shellyht-956332:
        powered: ac
      shellyht-955170:
        powered: ac
      shellyht-AC4EBD:
        powered: ac
      shellyswitch25-40F5202A2CFB:
        relay-0: switch
        relay-0-name: BP_S1
        relay-1: switch
        relay-1-name: BP_S2
      shellyix3-8CAAB542EB07:
        relay-0-name: BP_B1
        relay-1-name: BP_B2
        relay-2-name: BP_B3
      shellybutton1-A4CF12F44C5C:
        powered: ac
      shellyem-B043BE:
      shelly1pm-40F52000C59B:
Posted it. There aren’t many log entries or am I missing something?
2022-01-12 20:10:27 INFO (SyncWorker_0) [homeassistant.components.python_script] Executing shellies_discovery.py: {'id': 'wohnzimmer_deckenlicht', 'mac': 'XXXXXXXXXXXX', 'fw_ver': '20211109-124958/v1.11.7-g682a0db', 'model': 'SHSW-1'}
2022-01-12 20:10:27 ERROR (SyncWorker_0) [homeassistant.components.python_script.shellies_discovery.py] Error executing script: host value None is not valid, update shellies_discovery automation
log output:
2022-01-10 17:34:18 ERROR (SyncWorker_1) [homeassistant.components.python_script.shellies_discovery.py] Error executing script: expire_after value None is not an integer, check script configuration
Please read the changelog Release Version 0.41.0 · bieniu/ha-shellies-discovery · GitHub
