Now I know that the script is working. Check your MQTT broker with MQTT-Explorer. Do you see there topics from TRV?
This is not a log, this is a small part of the log.
I checked again and nothing regarding trv in shellies in MQTT explorerā¦ so donāt know whatās the real problemā¦ other shellies do normal popup in logsā¦ a little frustratingā¦
Yes, Iāve read it and this is exact the automation I use: Shellies Discovery Script - #1435 by panhans
Before I posted here Iāve checked the latest docs and refreshed the two automations.
2022-01-12 20:10:27 INFO (SyncWorker_0) [homeassistant.components.python_script] Executing shellies_discovery.py: {'id': 'wohnzimmer_deckenlicht', 'mac': 'XXXXXXXXXXXX', 'fw_ver': '20211109-124958/v1.11.7-g682a0db', 'model': 'SHSW-1'}
As you can see in the info log entry no host is given in the json data. Maybe thats why the script generates that error.
So, Iām stuckā¦
It seems as that TRV do not send any MQTT notificationā¦
Maybe should I try somehow to direct communicate to TRV (name: shellytrv-kuhinja)ā¦
Is that possibleā¦ Maybe to make sensors manuallyā¦
Looks like your TRV doesnāt communicate with the broker. Maybe wrong login/password?
Latest documentation is on GH GitHub - bieniu/ha-shellies-discovery: Script that adds MQTT discovery support for Shellies devices
Hi Bieniu
Thx for all your effort and work on this great script.
Yesterdays I upgraded to Version 0.43.5. A few minutes later my Energy Dashboard was no longer able to catch the Measure Data of my Shelly 3 EM. The System tells me that the last reset for those 3 sensors is missing. Could this be related to your changes in order to Refactor meter sensor in this Version?
Regards,
Dom
Please update the script.
Iām trying to get this script working. I have one shelly device configured for MQTT (others are still using native integration). The device is discovered, but only has one entity (upgrade button). The logs show this error:
2022-01-14 17:06:28 INFO (MainThread) [homeassistant.components.automation.shellies_announce] Shellies Announce: Running automation actions
2022-01-14 17:06:28 INFO (MainThread) [homeassistant.components.automation.shellies_announce] Shellies Announce: Executing step call service
2022-01-14 17:06:28 INFO (MainThread) [homeassistant.components.automation.shellies_discovery] Shellies Discovery: Running automation actions
2022-01-14 17:06:28 INFO (MainThread) [homeassistant.components.automation.shellies_discovery] Shellies Discovery: Executing step call service
2022-01-14 17:06:29 INFO (SyncWorker_5) [homeassistant.components.python_script] Executing shellies_discovery.py: {'id': 'shelly1-8CAAB555B17F', 'mac': '8CAAB555B17F', 'fw_ver': '20211109-124958/v1.11.7-g682a0db', 'model': 'SHSW-1', 'mode': '', 'host': '172.30.0.198'}
2022-01-14 17:06:29 DEBUG (SyncWorker_5) [homeassistant.components.python_script.shellies_discovery.py] id: shelly1-8CAAB555B17F, mac: 8caab555b17f, fw_ver: 20211109-124958/v1.11.7-g682a0db, model: SHSW-1
2022-01-14 17:06:29 DEBUG (SyncWorker_5) [homeassistant.components.python_script.shellies_discovery.py] {'topic': 'homeassistant/button/shelly1-8CAAB555B17F-update_firmware/config', 'payload': '{"name": "Shelly 1 8CAAB555B17F Update Firmware", "cmd_t": "~command", "payload_press": "update_fw", "en": "true", "uniq_id": "shelly1-8caab555b17f-update_firmware", "qos": 0, "avty_t": "~online", "pl_avail": "true", "pl_not_avail": "false", "dev": {"cns": [["mac", "8c:aa:b5:55:b1:7f"]], "name": "Shelly 1 8CAAB555B17F", "mdl": "Shelly 1", "sw": "20211109-124958/v1.11.7-g682a0db", "mf": "Allterco Robotics", "cu": "http://172.30.0.198/"}, "~": "shellies/shelly1-8CAAB555B17F/", "entity_category": "config", "dev_cla": "update"}', 'retain': True, 'qos': 0}
2022-01-14 17:06:29 DEBUG (SyncWorker_5) [homeassistant.components.python_script.shellies_discovery.py] Sending to MQTT broker: homeassistant/button/shelly1-8CAAB555B17F-update_firmware/config {"name": "Shelly 1 8CAAB555B17F Update Firmware", "cmd_t": "~command", "payload_press": "update_fw", "en": "true", "uniq_id": "shelly1-8caab555b17f-update_firmware", "qos": 0, "avty_t": "~online", "pl_avail": "true", "pl_not_avail": "false", "dev": {"cns": [["mac", "8c:aa:b5:55:b1:7f"]], "name": "Shelly 1 8CAAB555B17F", "mdl": "Shelly 1", "sw": "20211109-124958/v1.11.7-g682a0db", "mf": "Allterco Robotics", "cu": "http://172.30.0.198/"}, "~": "shellies/shelly1-8CAAB555B17F/", "entity_category": "config", "dev_cla": "update"}
2022-01-14 17:06:29 ERROR (SyncWorker_5) [homeassistant.components.python_script.shellies_discovery.py] Error executing script: name 'state_topic' is not defined
File "/usr/src/homeassistant/homeassistant/components/python_script/__init__.py", line 222, in execute
exec(compiled.code, restricted_globals)
File "shellies_discovery.py", line 3051, in <module>
NameError: name 'state_topic' is not defined
Is this a bug or have I done something wrong?
Already fixed, please update the script.
I will try today again from scratchā¦
Hoping to resolve discovery problemā¦
Thank you so much for all the hard work on the script! I used it to successfully discover a shelly motion, but canāt discover my shelly UNI for some reason. I get the following error:
Error executing script: Firmware dated 20210720 is required, update your device shellyuni-98CDAC24D66E
From the log:
2022-01-14 14:40:43 INFO (MainThread) [homeassistant.components.automation.shellies_discovery] Shellies Discovery: Running automation actions
2022-01-14 14:40:43 INFO (MainThread) [homeassistant.components.automation.shellies_discovery] Shellies Discovery: Executing step call service
2022-01-14 14:40:43 WARNING (MainThread) [homeassistant.helpers.frame] Detected integration that accessed discovery_info['properties'] instead of discovery_info.properties; this will fail in version 2022.6. Please report issue to the custom component author for remote_homeassistant using this method at custom_components/remote_homeassistant/config_flow.py, line 117: properties = info["properties"]
2022-01-14 14:40:43 INFO (SyncWorker_7) [homeassistant.components.python_script] Executing shellies_discovery.py: {'id': 'shellyuni-98CDAC24D66E', 'mac': '98CDAC24D66E', 'fw_ver': '20210105-095645/release-1.9@8517d431+', 'model': 'SHUNI-1', 'mode': '', 'host': '192.168.0.183', 'discovery_prefix': 'homeassistant'}
2022-01-14 14:40:43 ERROR (SyncWorker_7) [homeassistant.components.python_script.shellies_discovery.py] Error executing script: Firmware dated 20210720 is required, update your device shellyuni-98CDAC24D66E
File "shellies_discovery.py", line 1277, in <module>
ValueError: Firmware dated 20210720 is required, update your device shellyuni-98CDAC24D66E
Keep trying to update my firmware but it looks like I am on the latest shelly uni firmware:
FIRMWARE UPDATE
Current version: 20210105-095645/release-1.9@8517d431+
You have latest version on your device!
Hi Bieniu, thank you for the reply; I unfortunately tried that several times (including downgrading) and it was not working.
I figured out what my problem was - I didnāt realize I needed to enable cloud access to update the firmware and then could turn off cloud access after use the MQTT discovery script to keep everything local.
I hope this helps someone else with their troubleshooting. Thanks again!
Gen2 devices script preview: GitHub - bieniu/ha-shellies-discovery-gen2
Work in progress so use with caution!
Still no luck with TRV discoveryā¦ the only discovery was the entity of new FW updateā¦ but thinking that this has no relate to this script but to original shelly discoveryā¦
Sorry I donāt understand. Please post a debug log if you need help.
First release of Shellies Discovery Gen2 is available here GitHub - bieniu/ha-shellies-discovery-gen2
Community thread: Shellies Discovery Gen2 Script
Dear all,
in an effort to improve my home assistant set-up, among other things I renamed all devices. The naming convention contains a dash, which does not work well with Your script.
Is there a way to use the Shelly device name in all length as the entity ID? If so how?
For example: Shelly device name 15-02-Blinds-WindowLeft (set on the device itself) should translate to cover.15_02_blinds_windowleft. And with it all related entities.
Is this something you can help with?
