I have been making the switch to smart home very recently. Started whit Google home / Wiz lights combo now switched to HA. I am thinking of getting some Shelly 1 relays to integrate my normal and smart lights to be controlled by physical’s switches. From my experience so far wiz and its Wi-Fi connecting tends to fail sometimes. atm i am resolving this whit powering down the lights whit the physical switch for a few sec and then back on what normally connects them back to the wifi.
Now from what i found on the internet shelly cut the power to the lamps al together. This is not a problem for the normal lights but will cause minor issue’s whit the WIZ smart lights ( after a power cut it takes some time for them to show back up in HA. its not that long normally but it might mess up some automations)
What i would like to know is:
how does the relay function work on a shelly?
Can you config it that a physical switch change does not change the relay state but sends a wifi trigger to HA to change a smart light to on/off depending on its previous state and for sake of example 3 rapid state changes triggers the relay cutting power for x amount of seconds to the smart light itself in order to brute force it to connect to the wifi?
