Shelly 1 detached switch -No click event
Hi all
I have multiple Shelly 1’s installed at home which seem to work well with the built in Shelly HA integration. One of my switches, I am planning on using in detached switch mode with the switch firing an automation. Looking at the documentation (https://www.home-assistant.io/integrations/shelly/) I should be able to subscribe to the shelly.click event, however it does not seem to be firing when I check it in Developer Tools. The only click event I see is if I turn the switch on, then off again, I eventually see a “long” click type.
Did you solved this issue? I have the same situation and cannot find a solution for it.
