Hi all. I finally gave up on MyQ and decided to do a fully local replacement using a shelly1 following the instructions on this video https://www.youtube.com/watch?v=WEZUxXNiERQ
I wired it all up and it’s working correctly for the most part. The only part that is not working is that I can’t monitor the state of the door in Home Assistant.
I did wire the reed switch and in the shelly app it does show the state changing, but I’m not seeing a way to get that state change into homeassistant.
It occurs to me that the shelly 1 does have URL actions which I guess would trigger a call to an URL on different events, so I’m thinking it should be possible to update a sensor in homeassistant by putting an URL on these fields, but I have no idea what that URL should look like.
Any help here would be appreciated.
