Shelly 1 Mini Gen 3 Vs Shelly Plus 1
Hi there,
A month in with Home Assistant and I’m building up my confidence…
I’d like to control my bathroom extractor fans better in a utility room and in a bathroom. We don’t normally have the fans coming on every time the lights are on. I’d like to use the Shelly BLU H&T as a humidity sensor and it also has a switch. So my use case would be that if humidity increased or if someone pushed the button, then the fan would come on for a certain amount of time. Another example is in the utility room when the lights are off but humidity levels are high due to the clothes drier - so I’d like to automatically control the fan.
I couldn’t get my head round the difference between the Shelly 1 Mini Gen3 Vs Shelly Plus. I’d like to fit this behind the isolator switch. Ampage levels will be low as it is a simple fan. Both product pages talk about being able to control fans. Gen3 as a newer product might be better for future proofing.
I’ve seen some people doing similar projects struggle with LED lights glowing as a result. I definitely want to avoid that. The bathroom has dimmable LEDs. But considering my use cases above I think I can avoid connecting to the lighting circuit ie as a switch input.
Any pointers appreciated!
if you mean “shelly 1 mini gen3 vs shelly plus 1 mini” then HERE says:
The device is an improved version of Shelly Plus 1 Mini with a more advanced processor and increased memory . Shelly1 Mini Gen3 can be accessed, controlled and monitored remotely from any place where the User has internet connectivity, as long as the device is connected to a Wi-Fi router and the Internet.
Supposely gen3 is harder to reprogram it to esphome…
And, there’s also “PM” version, which can measure power.
Thanks for your reply.
I did actually mean the “Shelly Plus 1” as that was the first product I came across from Shelly which specifically mentioned controlling extractor fans.
Well, in that case the difference is size above all. Mini is … well, really mini… you can really squeeze it just about anywhere.
Shelly 1 mini gen3 also has esp32c inside, while shelly 1 has esp8266 almost certainly.
