rockas
(Valter Cunha)
October 8, 2023, 4:59pm
1
Hi folks,
I’m struggling to have Shelly 1 Plus Addon with a reed peripheral attached as Digital In.
Addon Configuration
however when looking at MQTT explorer just see the following:
I cannot confirm if I can see the right topic, think it’s input 100 but not sure.
Any guidance on confirming and how to setup yaml for home assistant.
I would say you’re on the right track there, with your entity being named input:100. As you can see from my explorer screenshot, mine show as temperature:100 through temperature:103
And as per step 6 in this post Shelly Plus 1PM with Add-on and DS18B20 temperature sensor help - Configuration - Home Assistant Community (home-assistant.io) , that is how I have my YAML configured for those Addon inputs. You probably need a garage door device_class, or something like that. Instead of my value_json.tC which extracts celsius temperature, it looks like your attribute is called state, so you’d need value_json.state I’d imagine.
I hope others here can add/confirm for you.
BTW. Your shelly plus 1pm internal temp is > 100 degrees celsius.
rockas
(Valter Cunha)
October 10, 2023, 5:16pm
4
Great feedback.
If anyone else could share their config here would be awesome.
rockas
(Valter Cunha)
October 15, 2023, 7:41pm
5
To whoever may need!
Include in configuration.yaml
mqtt: !include mqtt.yaml
Create mqtt.yaml and below code (side note, replace state_topic to sheelly.
- name: "MQTT Portão Garagem Sensor"
state_topic: "mqtt_S1plus_Teste/status/input:100"
value_template: "{{value_json.state}}"
payload_available: "true"
payload_not_available: "false"
