Shelly 1 plus | Device not fully provisioned
I’m trying to integrate a Shelly1 Plus
Adding it to the networks worked well, it showed up
But when adding got this message.
As part of the initial setup I upgraded the firmware to the latest v1.0.3
I have factory reset the switch but still get this message.
I’m on the following environment
Home Assistant 2023.8.2
Supervisor 2023.09.2
Operating System 10.4
Frontend 20230802.0 - latest
I found the issue…
Turns out HA discovered the Shelly with it’s DHCP assigned IP address. I’m using fixed IP addresses for certain type devices.
So HA tried to look for the Shelly at it’s dynamic IP whereas I have switched to the fixed IP in the meantime.
Restarted HA and all good.
