Shelly 1 Termination with Ferrules
I am using stranded 14AWG wire for my Shelly 1 which will be controlling a bath exhaust fan. A lot of people use ferrules on these before terminating the stranded wire to the terminal blocks. I’ve tried this method and for the life of me I cannot get the ferrules into the terminal blocks. Below are the ferrules and crimper I am using. Any insight or suggestions would be greatly appreciated, thanks.
IWISS Self-adjustable Crimping Tools Plier for AWG20-5 Bootlace End-sleeves Ferrule, Ratchat Wire Crimping Tool
AW25008 - 14AWG (8mm Pin) Insulated Ferrules
So I’ve answered my own question by trying a different style crimper. Using the 06WF die on setting 1.5 will get you what you need.
haisstronica Crimping Tool Set 6PCS-Ratchet Wire Crimping Tool for Heat Shrink,Insulated Nylon,Non-Insulated,Ferrule Wire End,Open Barrel Terminals
Martin,
I don’t understand which die. The kit has A-F. It says E is for Ferrules. You say 06WF set to 1.5.
