Iv got a Shelly 1 connected to the button that turns the leds on in my electric fire and have it set up to trigger the relay for .1 second and then turn off this turns the lights on and trigger it again to turn the lights off. Works great apart from home assistant doesn’t know if the fire is on or off only that the Shelly has been triggered. Is there anyway to make home assistant know when the fire is on or off?
Maybe with a counter odd number or times the Shelly has been toggled = fire on, even number of times the Shelly has been toggled = fire off?
Alternatively you could put a light or temperature sensor (ideally paired with another one somewhere near by) near the fireplace and see if you can detect either the light from the flames (probably hard) or the change in temperature compared to ambient temperature…
Create the helper
Go to Automation
Create an automation like this but using your entities
alias: Set Fire_on
description: Set the input_boolean when fire turned on and off
mode: single
- platform: state
entity_id: binary_sensor.family_room_fireplace_input
to: 'off'
condition: []
- service: input_boolean.toggle
entity_id: input_boolean.fire_on
This will set the condition of fire on and fire off.
It can get out of sink with the actual condition of the fireplace if you reboot etc.
Does this help?
Do you have a shelly pm? This would allow you to monitor power and you could skip this and always know when it was on or off.
