Need help on wiring or configuring shelly to work with TL (TL - 15520) i want to make this TL smart if i can.
So i wired my house with this type of teleruptors for switching same lighting for more then 2 locations and i want to use shelly to command this from my phone.
my initial try was to command A1/A2 with internal shelly contact, shelly need to be push button.
so TL works with push buttons, one push lights ON, another push lights OFF.
i will attach TL schematic
this is classic shelly 1 schematic
and this is my wiring (maybee wrong)
the light get L,N from TL NO contacts (20amps) 1 - 2 for L and 3 - 4 for N
so i test this configuration with shelly button type on toggle and momentary (both don’t work well)
with toggle set it’s working like this:
from physical push button it’s working (but button state on web interface doesn’t change )
i don’t know how to explain but i will try to describe what happens
it’s a 5 step cycle
1. step
lights OFF
TL - OFF state (no buzzing)
state light - OFF (state of switch on web interface)
2. step
press button from web interface
light ON
TL - ON state (relay start buzzing, like i keep press physical button)
state light - ON
3. step
light ON
TL - ON state (no buzzing)
state light - OFF
4. step
light OFF
TL - OFF state (relay start buzzing, like i keep press physical button)
state light - ON
- step
light OFF
state light - OFF
now if i change to momentary button type i must press 2 times the physical button to get the correct TL relay state for light to turn ON or OFF
i am open to any suggestion
