I’m searching to activate the overload protection of a Shelly 1PM.
The configurations I found, they are all about measuring the power, but no overload detection.
How to do this?
How to do this?
Well overload protection like these are very often just based on measured power
thank you, I knew the answer was simple, only I need the solution…
well setup an automation in ESPhome so that if power measured is above product specs, you switch off relay no ? (Automations and Templates — ESPHome)
I am not sure if the 1PM has the overpowering sensor, but if you look at the device page(where all the associated entities, automations, scripts etc are shown, it will be under “diagnosic” and may be diabled. If so click where it says “+ n disabled entities” and if it is exposed then enable it.
