Has anyone out there checked on the power monitoring of these devices when connected via Zigbee.
I noticed it wasn’t reading the correct power consumption.
I added it back into the Shelly app via WiFi (you can have both running as advice from Shelly)
This is the graph showing the readings of both. The Washer via Shelly is showing the correct readings. Zigbee readings are in Blue.
I’ll report back when Shelly reopens on 4 July but I was wondering if anyone else had noticed this issue.
Thanks in advance.
Same here Shelly PM1 no power readings above 300 or below -300 Watt - #5 by termeerh01 readings over Zigbee never comes above 300 Watt and never below -300 Watt. The other readings current, voltage etc are ok.
