anyone already flashed a Shelly 1PM device with ESPhome?
I ordered 1Pm because of additional security features (overheat, overload protection).
I plan to use it for my garden irrigation (just switch on/off) by mqtt. After shelly device, placing a 240V -> 12v adapter -> switch on/off a magnetic valve.
Any experience would be fine - or is this devcie same as the Shelly1 ?
I don’t own one, but from my understanding, it’s the same as a Shelly 1, but with the energy monitoring features of the shelly 2. So I imagine a combination of those two bits should work.
Why flashing with ESPHome? There is nice custom component to integrate Shelly (all types) with HA: https://github.com/StyraHem/ShellyForHASS
I hope it will be integrated someday with HA
I don’t have any Shelly products, but if I did I’d flash them with ESPHome even though there’s a custom component that can talk to them locally. I don’t want these devices talking to the cloud at all. Plus I’d bet that ESPHome is a lot more customizable.
Don’t get me wrong, I really like ESPHome. And I have a lot of devices using this.
I also have some shellys flashed with ESPHome, and it is really customizable.
But If you don’t have ESPHome installed yet, or don’t know how to flash devices. This sounds like a nice solution.
Also for the shelly roller shutter looks like it is better than the ESPHome cover version. I have a shelly 2.5 for my roller shutter to test, but didn’t try ESPHome on it. The shelly has autocalibration based on energy usage I think?
About the talking to the cloud: that’s what a firewall is for.
I’m thinking of getting some Shelly’s. Flashing looks to be no problem, but doesn’t the Shelly firmware have the possibility set it to MQTT mode that disables the Cloud functionality? If that’s the case there is no need to flash it with custom firmware.
Have anyone tested it with MQTT? Is it completely off the cloud when running it on MQTT?
Yes, in order to use MQTT it HAS to be disconnected from Shelly Cloud. That is how i am using 4 shellys, and they work great. There is a ton of functionality with the stock shelly firmware so i have not had the need to flash them.
Just wanted to share my esphome file. It’s calibrated by me according to frenck’s guide… It may need some calibration for you. I haven’t tried if the button sensor is working yet and I just remembered that it also got a temperature sensor. I will update with a fix for this later…
# From Tasmota template
# "NAME":"Shelly 1PM","GPIO":[0: Led1i,0,0,0,4: D_SENSOR_SWITCH,5: BL0937 CF,0,0,0,0,0,15: Relay1,0],"FLAG":2,"BASE":18}
substitutions:
plug_name: "shelly1pm"
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: !secret wifi_ssid
fast_connect: true
domain: !secret domain
manual_ip:
static_ip: 10.222.50.198
gateway: 10.222.50.1
subnet: 255.255.255.0
dns1: 10.222.50.1
# Enable logging
logger:
level: VERBOSE
# Enable Home Assistant API
api:
password: !secret password
ota:
time:
- platform: homeassistant
switch:
- platform: gpio
icon: "mdi:power-socket-eu"
pin: GPIO15
- platform: hlw8012
cf_pin: GPIO05
cf1_pin: GPIO13 # not used because it is not available on the 1PM but it is needed to compile
sel_pin: GPIO14 # not used because it is not available on the 1PM but it is needed to compile
power:
unit_of_measurement: W
icon: mdi:flash-circle
accuracy_decimals: 0
filters:
# Map from sensor -> measured value
- calibrate_linear:
- 0.0 -> 1.0
- 110.33186 -> 20.62
- 131.01909 -> 24.32
- 341.33920 -> 62.08
- 5561.41553 -> 1000.0
- 2975.51221 -> 535.7
- 9612.66309 -> 1720.0
- 14891.35352 -> 2679.0
# Make everything below 2W appear as just 0W.
# Furthermore it corrects 1.0W for the power usage of the plug.
- lambda: if (x < (2 + 1)) return 0; else return (x - 1);
update_interval: 3s
binary_sensor:
# Binary sensor for the button press
- platform: gpio
pin:
number: GPIO4
inverted: true
on_press:
- switch.toggle: relay
output:
# Relay state led
- platform: esp8266_pwm
pin:
number: GPIO00
inverted: true
I looked at the tasmota config.
The temperature sensor were a bit more complicated. I think i will need to write some logic and push it to esphome to make it work. I don’t really know when I got time for it. I will make a feature request for it, maybe someone else got time
Thermistor seems to be working here. I predicted the componentry would be similar to the Shelly 2.5, so I copied the thermistor part from my shelly 2.5 config and it seems to also work for the shelly 1pm. Luckily the ESP8266 doesn’t have many analog inputs (one to be exact), and it’s likely manufacturers have saved by using the same components for the thermistor divider on all their products. So it was an easy guess. I haven’t frozen it or caught it on fire, or otherwise calibrated it, but it seems reasonable hovering around 37C after warming up on my desk, and jumping up when I heat it with a blow dryer.
I haven’t hooked it up to mains voltage to calibrate it yet, and the power reading seems to be floating around 37-40W (this could be from floating nodes in the circuit due to not being wired up). The LED is correct, OTA works (didn’t with the PWM led config above), and not sure if the relay works until I wire it up. If it does, the relay is super duper quiet because I can’t hear it click when I toggle it (at least compared to my Shelly 2.5 relay’s).
substitutions:
friendly_name: "Garage Lights"
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ap:
ssid: "${friendly_name} Fallback Hotspot"
password: "oops"
# Enable logging
logger:
api:
password: !secret garage_lights_password
ota:
password: !secret ota_password
switch:
- platform: gpio
icon: "mdi:power-socket-us"
pin: GPIO15
- platform: wifi_signal
name: "${friendly_name} WiFi Signal"
update_interval: 60s
- platform: hlw8012
cf_pin: GPIO05
power:
filters:
update_interval: 10s
# NTC Temperature
- platform: ntc
sensor: ${name}_resistance_sensor
name: "${friendly_name} Temperature"
unit_of_measurement: "°C"
accuracy_decimals: 1
icon: mdi:thermometer
calibration:
b_constant: 3350
reference_resistance: 10kOhm
reference_temperature: 298.15K
- platform: resistance
sensor: ${name}_source_sensor
configuration: DOWNSTREAM
resistor: 32kOhm
- platform: adc
pin: A0
binary_sensor:
- platform: status
- platform: gpio
pin:
number: GPIO4
inverted: true
status_led:
pin: GPIO0
Got it wired up today and all is working well; current, voltage, relay, input switch, and temperature!
The calibration of the power sensor is way off, showing 700W for what should be a <100W or so load. I’ll be calibrating this with my diy ‘killer watts’ meter, but otherwise consider this a working shelly 1pm config. Regardless, the sensor is responding properly, so calibration is all that is needed here.
I included some small automations to make the existing toggle style wall switch behave like a standard wall switch (up=on, down=off). I also have node red doing some additional automations based on motion, luminance, and switch position, but that’s out of the scope of this post. Hope this helps someone down the line!
# Shelly 1pm Example#############################
substitutions:
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ap:
password: "oops"
# Enable logging
logger:
api:
ota:
switch:
- platform: gpio
pin: GPIO15
- platform: hlw8012
cf_pin: GPIO05
power:
filters:
#Reading -> actual
- calibrate_linear:
- 2.5 -> 0.16
- 747.0 -> 125.0
- 1409.0 -> 237.0
- 2663.0 -> 444.0
- 8600.0 -> 1390.0
- lambda: if (x <= 6.0) return 0; else return (x - 6);
# NTC Temperature
- platform: ntc
calibration:
b_constant: 3350
resistor: 32kOhm
- platform: adc
pin: A0
binary_sensor:
- platform: status
- platform: gpio
pin:
number: GPIO4
on_state:
#on_press:
# - switch.turn_on: relay
#on_release:
# - switch.turn_off: relay
status_led:
pin: GPIO0
[edit: Got my calibration done… added it to this config. Incidentally, that’s the farthest off from calibration I’ve ever seen a sensor… not that it means anything, but usually output values are within a few 10% before calibrating, not ~800% off as in this case. Either way, a linear calibration does look valid for the sensor (roughly the same 8x factor across the range).]
@truglodite Thanks for your config. Finally able to calibrate the temperature sensor. I tried it without the ntc platform which wasn’t that clever
Thats because of the relativly high shunt resistor value compared to the Sonoff’s (which are used for the default values in ESPHome). Higher Shunt Resistor value means higher accuracy when measuring the power consumtion but also higher heat dissipation which is why the shelly overheat when having >1000W for longer time. (Didn’t verify myself but read it)
I tried to implement a logic to turn off the relay when a cricical temperatur was reached. Not perfect since it still turns on the switch for at least 100ms. Maybe I can do something better with template switches and lambdas.
I use nodered for all my automations, and I basically have it shut off the relay if either the temp or current go over spec. There’s no interval, but my safety method still does have to wait for the shelly to report the data. Since temps are only reported every 3sec (I figure that’s fast enough to catch something overheating), and watts are reported on state change, I may have a 3sec delay before trigger. That’s a lot worse than 100ms.
I think what you’re doing there is fine, and I will eventually convert my setup to do the same soon (keeping the safety internal on the esp so no HA requirement, and using an interval). I think 100ms is plenty fast don’t you? I suppose some sort of interrupt could be configured, but that might cause issues coming from an analog sensor pin, if even possible. At the end of the day, I think the best design would involve shelly adding a thermal switch, which could then be hooked to an interrupt for instant response… but then again we have the response of the thermal switch, lol.
