Is anyone using this with a light switch and have it working where the relay in the shelly “follows” the switch? For example, if you turn the light or whatever it is controlling on using HA, obviously the physical switch would still be in the off position. Then if you flip the physical switch to the on position, nothing would happen until you move the physical switch to the off position. I know it might seem petty, but I like for my smart relays to follow my physical switches. I don’t want the physical switch to just be a toggle.
I tried to convert one of my shelly1PM to esphome starting with mgos2tasmota OTA. It was powered with 230v. Looking at the log, it downloaded the tasmota firmware. Then it went offline and never came back. It took it out and have been trying to get a serial connection with no luck. I use a PL2303 USB to serial thing, booting with GPIO0 grounded and not. I’ve tried TX/RX both ways using 5 different softwares with no luck. Could the ESP chip have been fried because of the alternative firmware?
EDIT: I tried esptool, and for some reason it managed to connect and flash. Problem solved.
Has anyone succeeded with the temperature sensor addon? I tried GitHub - persuader72/esphome-components: Custom esphome components but it won’t work.
This part should solve your problem. Just comment out the toggle part and uncomment the rest. Let me know if it works. Thanks!
Hi I just wanted to bump this thread.
I converted over my Shelly 2.5s to ESP Home out of frustration with the MQTT auto-discovery script and the inability to easily create a device in YAML rather than creating single entities not tied together in 1 device (yes I know attributes exist but it’s just not the same as a device).
Anyway after setting the config file to just the way I like I realised the power monitoring is wildly off. Scavenging off forum threads this is the best config I can make.
Does anyone have suggestions on how to make the power monitoring more accurate for Shelly 2.5’s? I’m using linear calibration, I actually had worse results with polynomial 2 and 3 degree’s (I haven’t tried 5 degrees) I’m thinking of just disabling the sensors at this rate as I have whole home power monitoring.
substitutions:
friendly_name: Bedroom Ensuite Secondary Light Switches
device_name: bedroom-ens-sec-light-switches
channel_1: Bedroom Ensuite Heat Lamps
channel_2: Bedroom Ensuite Lightstrip
ssid: !secret wifi_ssid
max_power: "2000.0"
max_temp: "80.0"
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: ${ssid}
password: ${password}
power_save_mode: HIGH # for ESP8266 LOW/HIGH are mixed up, esphome/issues/issues/1532
ap:
ssid: ${device_name}
captive_portal:
logger:
api:
ota:
web_server:
port: 80
version: 1
time:
- platform: sntp
i2c:
sda: GPIO12
scl: GPIO14
- platform: ade7953
irq_pin: GPIO16 # Prevent overheating by setting this
voltage:
# On the Shelly 2.5 channels are mixed ch1=B ch2=A
current_a:
internal: true
current_b:
internal: true
active_power_a:
# active_power_a is normal, so don't multiply by -1
filters:
- calibrate_linear:
- 0.0 -> 0.0
- 70 -> 10
- 4600 -> 600
# Make everything below 2W appear as just 0W.
# Furthermore it corrects 1.0W for the power usage of the plug.
- lambda: if (x < (2 + 1)) return 0; else return (x - 1);
on_value_range:
- above: ${max_power}
then:
- light.turn_off: shelly_light_2
- homeassistant.service:
service: persistent_notification.create
title: Message from ${friendly_name}
data_template:
message: Switch turned off because power exceeded ${max_power}W
active_power_b:
# active_power_b is inverted, so multiply by -1
filters:
- multiply: -1
- calibrate_linear:
- 0.0 -> 0.0
- 70 -> 10
- 4600 -> 600
on_value_range:
then:
- light.turn_off: shelly_light_1
data_template:
update_interval: 5s
- platform: total_daily_energy
power_id: power_channel_1
filters:
# Multiplication factor from W to kWh is 0.001
- multiply: 0.001
unit_of_measurement: kWh
power_id: power_channel_2
filters:
- multiply: 0.001
# NTC Temperature
- platform: ntc
sensor: temp_resistance_reading
name: ${friendly_name} Temperature
unit_of_measurement: "°C"
accuracy_decimals: 1
icon: "mdi:thermometer"
calibration:
b_constant: 3350
reference_resistance: 10kOhm
reference_temperature: 298.15K
on_value_range:
- above: ${max_temp}
then:
data_template:
message: Switch turned off because temperature exceeded ${max_temp}°C
- platform: resistance
sensor: temp_analog_reading
configuration: DOWNSTREAM
resistor: 32kOhm
- platform: adc
pin: A0
status_led:
pin:
number: GPIO0
inverted: yes
output:
- platform: gpio
pin: GPIO4
- platform: gpio
pin: GPIO15
light:
- platform: binary
output: shelly_relay_1
icon: "mdi:heat-wave"
restore_mode: RESTORE_DEFAULT_ON
- platform: binary
output: shelly_relay_2
icon: "mdi:led-strip-variant"
binary_sensor:
- platform: gpio
pin:
number: GPIO13
name: "${channel_1} Switch Input"
- platform: gpio
pin:
number: GPIO5
name: "${channel_2} Switch Input"
When doing polynomial calibration, it’s worth checking the result with a spreadsheet. I don’t know if they use the same curve fitting algorithms as esphome, but it might receal some surprising results.
