Hi
I have two shelly’s 2.5 one for my room balcony door shutter and one for the window shutter.
I configured the mqtt and I can control the shutters through the Shelly web interface.
But I am trying to add the two shelly’s on the Home Assistant Dashboard UI cards but no success.
I Can add one but when I add the other one its override the first one , also I tried the groups , in the best case I have both of them but the down arrow disabled as u see in the attached image below … any suggestions ? Thanks
My configuration.yaml code and see
cover:
- platform: mqtt
state_topic: "shellies/shellyswitch25-693FA7/roller/0"
command_topic: "shellies/shellyswitch25-693FA7/roller/0/command"
position_topic: "shellies/shellyswitch25-693FA7/roller/0/pos"
set_position_topic: "shellies/shellyswitch25-693FA7/roller/0/command/pos"
payload_available: "true"
payload_not_available: "false"
qos: 1
retain: false
payload_open: "open"
payload_close: "close"
payload_stop: "stop"
position_open: 100
position_closed: 0
optimistic: false
- platform: mqtt
state_topic: "shellies/shellyswitch25-68EF11/roller/0"
command_topic: "shellies/shellyswitch25-68EF11/roller/0/command"
position_topic: "shellies/shellyswitch25-68EF11/roller/0/pos"
set_position_topic: "shellies/shellyswitch25-68EF11/roller/0/command/pos"
qos: 1
retain: false
position_open: 100
position_closed: 0
optimistic: false
