hello, I’m trying to connect my shelly 2.5 to Hassio as a roller shutter, I use the addon mosquitto broker, from the logs it appears that the shelly connects but then immediately says that it is disconnected, how do I?
mqtt config:
"logins": [],
"anonymous": true,
"customize": {
"active": true,
"folder": "mosquitto"
"certfile": "fullchain.pem",
"keyfile": "privkey.pem",
"require_certificate": false
log mqtt:
1569739898: New client connected from 192.168.1.23 as shellyswitch25-E59F4A (p2, c1, k60).
1569739926: Client auto-2566634F-842E-37A4-9321-0C30B0878A28 disconnected.
configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, e>default_config:
# Uncomment this if you are using SSL/TLS, running in Docker co># http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
cover:
- platform: mqtt
command_topic: "shellies/shellyswitch25-E59F4A/roller/0/co> position_topic: "shellies/shellyswitch25-E59F4A/roller/0/p> set_position_topic: "shellies/shellyswitch25-E59F4A/roller> availability_topic: "shellies/shellyswitch25-E59F4A/online" payload_available: "true"
payload_not_available: "false"
qos: 1
retain: false
payload_open: "open"
payload_close: "close"
payload_stop: "stop"
position_open: 100
position_closed: 0
optimistic: false
