Shelly 2.5 getting hot to touch (63°C external case) - should I be worried?
light or switch - config is very similar if not the same. Also shelly1, 1pm, 2.5 are the same in regard of mqtt relay configuration
It differs in a domain the definition is member of. (see mqtt light and mqtt switch documentation).
comparing to post above I would define more details for the entity. Here is config of relay 0 one of my shellies 2.5. For second relay you need to duplicate the code changing name and relay number from 0 to 1.
Also note, Shelly2.5 provides sensors (internal temp and power usage)
  - plateform: mqtt
    command_topic: "shellies/shelly25-entrance/relay/0/command"
    state_topic: "shellies/shelly25-entrance/relay/0"
    availability_topic: "shellies/shelly25-entrance/online"
    qos: 1
    retain: false
    payload_on: "on"
    payload_off: "off"
    payload_available: "true"
    payload_not_available: "false"
    optimistic: false
Just built in a shelly 2.5 esphome flashed…
Instantly (after a few minutes) lights out and message on app… temperature too high… Is this normal? Only 300W lamp connected…
max_temp was set by me at 75… now I have set it at 85…
Is this normal behavior??
substitutions:
devicename: shelly_25_01
  # ip: 192.168.xx.xx
  channel_1: Relay 1
  channel_2: Relay 2
  ssid: IOTDOM
  password: !secret IOTDOM_wifi_key
  max_power: "2000.0"
  max_temp: "85.0"
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "IOTDOM"
  domain: !secret domain
  use_address: 192.168.6.28
  ap:
    ssid: "${devicename} Fallback Hotspot"
    password: !secret Fallback_Hotspot
captive_portal:
# Enable logging
logger:
  level: DEBUG
# Enable Home Assistant API
api:
ota:
web_server:
  port: 80
time:
  - platform: sntp
i2c:
  sda: GPIO12
  scl: GPIO14
  - platform: ade7953
    voltage:
    current_a:
      internal: true
    current_b:
      internal: true
    active_power_a:
      filters:
        - multiply: 1
      on_value_range:
        - above: ${max_power}
          then:
            - switch.turn_off: shelly_relay_2
            - homeassistant.service:
                service: persistent_notification.create
                  title: Message from ${devicename}
                data_template:
                  message: Switch turned off because power exceeded ${max_power}W
    active_power_b:
      filters:
        - multiply: -1
      on_value_range:
          then:
            - switch.turn_off: shelly_relay_1
                data_template:
    update_interval: 30s
  - platform: total_daily_energy
    power_id: power_channel_1
    filters:
      # Multiplication factor from W to kW is 0.001
      - multiply: 0.001
    unit_of_measurement: kW
    power_id: power_channel_2
    filters:
      - multiply: 0.001
  # NTC Temperature
  - platform: ntc
    sensor: temp_resistance_reading
    name: ${devicename} temperature
    unit_of_measurement: "°C"
    accuracy_decimals: 1
    icon: "mdi:thermometer"
    calibration:
      b_constant: 3350
      reference_resistance: 10kOhm
      reference_temperature: 298.15K
    on_value_range:
      - above: ${max_temp}
        then:
              data_template:
                message: Switch turned off because temperature exceeded ${max_temp}°C
  - platform: resistance
    sensor: temp_analog_reading
    configuration: DOWNSTREAM
    resistor: 32kOhm
  - platform: adc
    pin: A0
status_led:
  pin:
    number: GPIO0
    inverted: yes
switch:
  - platform: gpio
    pin: GPIO4
    icon: "mdi:electric-switch"
    restore_mode: RESTORE_DEFAULT_OFF
  - platform: gpio
    pin: GPIO15
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO5
    on_state:
      then:
        - switch.toggle: shelly_relay_1
  - platform: gpio
    pin:
      number: GPIO13
    on_state:
      then:
        - switch.toggle: shelly_relay_2
Check this:
@makai THANK YOU!!!
I think ESPHome already addressed the problem by adding the irq_pin.
Still my units get hotter than 75°C is this still normal?
# If you change the light for a sitch or the other way around,
# make shure to also change
# the automation service call "light.turn_off" / "swich.turn_off".
#Variables
substitutions:
  device_name: shelly_5_25_kitchen
  node_name: Shelly25 Kitchen
  # Name for the relays
  channel_1: Kitchen Spot
  channel_2: Kitchen Exhaust Fan
  max_power: "2000.0" # watt
  max_temp: "80.0" # °C
# Basic Config
esphome:
  platform: ESP8266
  board: esp01_1m
  build_path: ./build/${device_name}
wifi:
  use_address: 10.25.30.107
packages:
  #Wifi Settings
  wifi: !include includes/network.yaml
#Device Specific Config
script:
  - id: protection_temp
    then:
      - light.turn_off: channel_1
      - fan.turn_off: channel_2
            title: Message from ${node_name}
          data_template:
  - id: protection_power
    then:
          data_template:
            message: Switch turned off because power exceeded ${max_power}°C
i2c:
  sda: GPIO12
  scl: GPIO14
  - platform: ade7953
    irq_pin: GPIO16
    voltage:
    current_a:
    active_power_a:
      filters:
        - multiply: 1
      on_value_range:
        then:
          - script.execute: protection_power
    current_b:
    active_power_b:
      filters:
        - multiply: 1
      on_value_range:
        then:
    update_interval: 60s
  # NTC Temperature
  - platform: ntc
    name: ${node_name} Temperature
    calibration:
      b_constant: 3350
    on_value_range:
      then:
        - script.execute: protection_temp
    resistor: 32kOhm
  - platform: adc
    pin: A0
## Changed to always off under switch component
#status_led:
#  pin:
#    number: GPIO0
#    inverted: yes
## Added to turn off status led
switch:
  - platform: gpio
    pin:
      number: GPIO0
      inverted: true
    restore_mode: ALWAYS_OFF
    internal: true
output:
  - platform: gpio
    pin: GPIO15
  - platform: gpio
    pin: GPIO4
fan:
  - platform: binary
    output: out_channel_2
light:
  - platform: binary
    output: out_channel_1
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
    on_state:
      then:
        - light.toggle: channel_1
    internal: true
  - platform: gpio
    pin:
      number: GPIO5
    on_state:
      then:
        - fan.toggle: channel_2
    internal: true
I don’t know. Add a binary sensor for gpio 16 and check again
it’s already in:
  - platform: ade7953
    irq_pin: GPIO16
Ok but that doesn’t seems to work. So follow the link above and add:
binary_sensor:
  - platform: gpio
    pin: GPIO16
    name: "ade7953 IRQ pin"
    internal: true
If then it’s working as expected, open an issue at Esphome GitHub about irq_pin
My Shelly 2.5 is at 50C with no load and almost 70C with just 40W (like 15W+25W) total load, using the original firmware. It is in a closed fuse box in a basement at like 14C.
My understanding is that if you want to drive any load you should probably put a proper contactor/relay in between or simply use 2 x Shelly 1 which have a dry relay. I have a Shelly 1 with like 300W and by touch it does not seem to get very hot.
From some discussions on the Shelly forums, it seems the manufacturer claims it is ok to have high temperatures with the 2.5 but, like most users i guess, I do not feel good about it reaching 80C or 90C.
link possible?
I did not have it handy but with a bit of digging i think i had this one in mind:
https://www.shelly-support.eu/forum/index.php?thread/3957-dimmer-2-overtemperature-error/&postID=55063#post55063
There are a few discussion on overheating on their forum: if you search you may find more useful data points.
That said i like very much the Shelly devices because they are more opened than most devices right out of the box and they don’t try to push their app and cloud down your throat. Just have to be aware of the practical vs theoritical load limits.
That is about a dimmer, not the shelly 2.5…
Right. But it does not matter much: the 1PM, 2.5 and any without dry relay are subject to overheating.
That said, I found the more relevant post involving one of their technical guy (it was not on their forum as i thought but only linked from their forum to their facebook page):
https://m.facebook.com/groups/1686781668087857?view=permalink&id=2054834997949187
Their tech support is relatively responsive so if you need more details probably best to go directly to the source.
I can confirm they (Shelly) claims what JeanC said about S2.5.
it doesn’t change the fact that such temperatures might be limitting as well as one might have concerns about energy loss/waste
Ok, but formally now “what is said then” :thinking:, in other words… is 90 to 95 degrees safe and cut off at 95 normal? Even if it “can get 120 degrees” :flushed:. That facebook post does not make things more clear but more vague :sweat_smile:
FWIW, I measured the case temperature of a Wemo Insight plug. A washing machine is connected to it and typically draws from 200 to 450 watts depending on the washing cycle. While it was part way through a spin cycle (consumes more power) I took several measurements and the highest value was 37.2 C (99 F).
I also have a refrigerator connected to a CE Smart Plug with Energy Monitoring (flashed with Tasmota). It consumes about 150 watts (when the compressor kicks in) and the plug’s case temperature is just a few degrees above ambient.
Right it is not a tech doc. I think he tried to say they cut 10C below rating of the components (105C) and that they are confortable with that margin. Personally i am not :slight_smile:
Anyone with Shelly 2.5 UL version can confirm if temperatures are different?
i would be interest too in knowing it
wifi:
  power_save_mode: HIGH
This has made the biggest difference with my shelly’s
