I’m experiencing random issues with all my shelly’s 2.5 (as roller shutters) working with MQTT.
It just happens sometimes, the issue is that when one of the automations open the rollers, the state of the roller has not changed.
I mean, the automation open the roller, but the state of the roller is still as “closed” (in home assistant and in shelly app).
Sometimes happen with one roller, and the next day with another one…
Does anyone know why this happens?
This is the configuration I’m using in home assistant for every roller:
My friend has maybe found the issue.
Could you please check if in the original shelly app you have a weird device ( duplicate in the UI as switch 1 and switch 2?) I mean, it’s not really a roller state as only one device.
If it’s the case, you have to remove completely the device and restart all the process to add it into the app and change it as a roller device.
Here, do you have only one device by shelly and recognized as roller?
Its my screen but you can see I have only one line by device and its a roller.
Thanks for your suggestions
Unfortunately it’s not the case, I don’t have duplicate devices in shelly app…
Now I’m trying with the official shelly integration in HA, but I’m still experiencing the same random issues…
It’s really an strange problem…
Hello.
I have the same issues, but only with the covers, the other Shelly’s I have working with lights work well via mqqt.
I don’t understand what’s happening.
Hi - I have just arrived here to find a solution for a quite similar problem - istead of opening a new question I decided to reply to this old one - maybe you have solved your problem meanwhile and could help me to solve my problem, too?
I have a shelly 2.5 connected to my roller shutter using MQTT. Here is my code from configuration.yaml.
My automation works fine as I can see in the homeassistant logs- and also the hardware switches work as expected. But randomly the roller just opens at night without a reason. The automation did not do that (as I can see in the logs) and the hardware buttons did not open it as well. So there ist some message from the broker I guess that forces the shelly to open. The same thing happens when I restart the shelly from web interface - I guess that there is something like a startup message from the MQTT broker that forces the shelly to act - although I set the shellies ‘Power On Parameter’ to STOP.
So hopefully someone can help me with that - my wife does not find it funny anymore when our shutters open randomly at night - and so I am really in trouble
