Hey all
Long time HA user, first time poster
I recently got some Shelly 2.5’s and I’m having issues with the setup/installation
PROBLEM:
EDIT: It appears the issue is coming from the “retain” flags, but I’m still not sure how to clear this up. everywhere I’m reading says “retain” should be set to false. I’m set Tasmota to SwithRetain 0, buttonRetain 1, buttonRetain 0, and powerretain 1. I think the retain flag is holding on to the prior values somehow.
EDIT 2: SOLVED -
I was able to solve this by in the Tasmota console setting switchtopic 1 and switchretain 1. This, I believe, passes the “retain = ‘y’” flag when you manually flip the light switch. For some reason, i needed ALL of my triggers to include the retain = y flag. This seems like a work around, but either way…it’s finally working
When I use the wall switch to turn the light on/off, it immediately flips back to the prior state.
MY SETUP:
1). I flashed my Shelly 2.5 with Tasmota (everything went perfect, as instructed by this link)
https://michlstechblog.info/blog/tasmota-flashing-and-setup-a-shelly-2-5/
2). I installed the Shelly 2.5 just as the image here.
https://skylerh.com/wp-content/uploads/2020/04/SkylerH-Shelly-2.5-Wiring-12.jpg
3). configuration.yaml is returning NO errors and is set as below
- platform: mqtt
entity_id: switch.kitchen_light_1
name: "Kitchen Light 1"
state_topic: "stat/playroom_kitchen_main/POWER2"
command_topic: "cmnd/playroom_kitchen_main/POWER2"
availability_topic: "tele/playroom_kitchen_main/LWT"
payload_on: "ON"
payload_off: "OFF"
state_on: "ON"
state_off: "OFF"
payload_available: "Online"
payload_not_available: "Offline"
optimistic: false
qos: 1
retain: true
4). In the Tasmota console I can see that the state is being updated when I use the wall switch (example: POWER: OFF becomes POWER:ON)
What am I missing?
Thanks all
