I’m using a Shelly 2.5 for two light sources (light 1 and light 2).
But the two switches are showing up with the same name (especially in Apple Home). How can I give the two switches different names?
I believe you need to ask Apple that.
You can use the channel name. I don’t know if that works in Apple Home.
Go to the IP address of the device in your browser
Select the setting for the channel (Wheel in red circle)
Select settings
Select Channel Name
Do I have to add something in the configuration file?
I’ve only this code:
shelly:
devices:
- id: "xxx"
sensors:
- all
I have nothing in my configuration.yaml and only use the HA shelly integration
