After thoroughly searching this forum and google. I have to ask.
Can I easiliy flash a shelly 2 dimmer with esphome?
Preferably with:
- OTA
- A valid yaml example
Preferably with:
There doesn’t seem to be a valid firmware yet, if you follow this: https://github.com/arendst/Tasmota/issues/6914
I assume, ESPhome has the same problem.
Hmz… anyone aware of any comparable wifi builtin dimmer flash able with esphome?
Please
there must be something
Why can’t you stick with shelly FW?
I hate cloud
Me too.
All Shelly devices can be configured to work without cloud. You can chose between MQTT and HTTP API (in fact enabling MQTT disables cloud as Shelly cannot handle both at the same time)
But mqtt does only enable the “control” but not the “informational” part correct?
Don’t know what you mean.
When you enable mqtt in shelly, everything goes through mqtt. nothing is sent to cloud.
Tasmota seems to have it… I prefer esphome (standardise).
I’m running several, all with no cloud access, but I too just want to consolidate. Just want the satisfaction of deleting another app!
Hopefully now that the Dimmer is supported on Tasmota, it will be a matter of time to make it to ESPHome. May try to go the Tasmota route for now.
Using Shelly original firmware you don’t need to use any app at all.
Sure … but if I want to change my Wi-Fi network, I need to go back and download the app. Consolidation is key to my sanity!
I have configured almost 100 devices snd never used Shelly app (actually not even installed it).
If you have in mind migrating all shelly devices to new Wifi all at once, you can write simple script to call http api provided by each shelly device.
No app needed. All configuration can be done via browser interface.
I’ll give a good reason why I want ESPHome on my Shelly Dimmer 2. So I can invert the value of the switch inputs. That’s not possible using stock Shelly firmware.
Hi, i’ve made a configuration for the Shelly Dimmer 2 that i would like to share with the community. I worked on top of previous solutions and improved upon it. On the internet, some solutions have been shared that contain a bug in the overheating protection feature. This is fixed in the solution below. For details about the bug, please follow this link: https://github.com/esphome/issues/issues/3487#issuecomment-1537475866
The solution below contains several features:
esphome:
friendly_name: ${device_name}
comment: Shelly Dimmer 2
substitutions:
device_name: "Name of the Light"
light_name: "Light"
max_temp: "70" # °C
esp8266:
board: esp01_1m
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "your encryption key"
ota:
password: "your ota key"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "ssid name"
password: "password"
captive_portal:
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 115200
light:
- platform: shelly_dimmer
leading_edge: false #choose between leading edge and trailing edge (use trailing edge for led dimming)
min_brightness: 470
max_brightness: 1000
restore_mode: ALWAYS_OFF
default_transition_length: 1s
gamma_correct: 0 #change this to your liking. Default value is 2.8, but 0 prevents some brightness pops for me
firmware:
version: "51.6"
update: true
sensor: #Important: don't change this sensor-part unless you know what you are doing. These sensors will shut the light down when overheating temperature is reached.
# NTC Temperature
- platform: ntc
sensor: temp_resistance_reading
unit_of_measurement: "°C"
accuracy_decimals: 1
icon: "mdi:thermometer"
calibration:
b_constant: 3350
reference_resistance: 10kOhm
reference_temperature: 298.15K
on_value:
then:
- if:
condition:
- sensor.in_range:
above: ${max_temp}
- light.is_on: dimmer
then:
- light.turn_off:
- logger.log: "Switch turned off because temperature exceeded ${max_temp}°C"
- homeassistant.service:
service: persistent_notification.create
title: Message from ${device_name}
data_template:
message: Switch turned off because temperature exceeded ${max_temp}°C
on_value_range:
- above: ${max_temp}
then:
- logger.log: "Temperature exceeded ${max_temp}°C"
data_template:
message: Temperature exceeded ${max_temp}°C
- platform: resistance
sensor: temp_analog_reading
configuration: DOWNSTREAM
resistor: 32kOhm
- platform: adc
pin: A0
switch:
- platform: restart
script:
- id: script_dim_down_timer
mode: restart # script will be kept running for 5 seconds sinces the latest time the script is executed
then:
- logger.log: "Dim-down timer script started"
- delay: 5s
- logger.log: "Dim-down timer script finished"
- id: script_dim_up_timer
then:
- logger.log: "Dim-up timer script started"
- delay: 5s
- logger.log: "Dim-up timer script finished"
mode: single # script will run once
then:
- logger.log: "Dim-down script started"
- while:
condition:
and:
- script.is_running: script_dim_down_timer #makes sure that dimming will stop after the set period
- light.is_on: dimmer #prevents dimming of a light that is off
- lambda: 'return(id(dimmer).remote_values.get_brightness() >= 0.01);' #prevents the light from going off and prevents the script from running unnecessary long (it stops at 1% brightness)
then:
- light.dim_relative:
relative_brightness: -0.5%
transition_length: 0.01s
- delay: 0.01s
- logger.log: "Dim-down script finished"
- id: script_dim_up
then:
- logger.log: "Dim-up script started"
- while:
condition:
and:
- script.is_running: script_dim_up_timer #makes sure that dimming will stop after the set period
- lambda: 'return(id(dimmer).remote_values.get_brightness() <= 0.999);' #prevents the script from running unnecessary long (it stops at 100% brightness)
then:
relative_brightness: 0.5%
- delay: 0.01s
- logger.log: "Dim-up script finished"
- id: script_turn_on_off
mode: single
then:
- logger.log: "Turn_on_off script started"
- if:
condition:
light.is_on:
then:
- light.turn_off:
- logger.log: "Light turned off"
else:
- light.turn_on:
brightness: !lambda |-
return id(dimmer).remote_values.get_brightness();
- logger.log: "Light turned on with previous brightness setting"
binary_sensor:
- platform: gpio
pin:
number: GPIO12
mode: INPUT
internal: false
on_multi_click:
- timing:
- ON for at most 300ms
then:
- logger.log: "Physical short press (dim_down) trigger"
- script.execute: script_turn_on_off
- timing:
- ON for at least 300ms
then:
- logger.log: "Physical long press (dim_down) trigger"
- script.execute: script_dim_down_timer
on_release:
then:
- if:
condition:
light.is_on:
then:
- logger.log: "Physical dim_down release trigger"
- script.stop: script_dim_down_timer
- logger.log: "Script_dim_down_timer stopped"
- platform: gpio
pin:
number: GPIO14
mode: INPUT
internal: false
on_multi_click:
- timing:
then:
- logger.log: "Physical short press (dim_up) trigger"
- timing:
then:
- logger.log: "Physical long press (dim_up) trigger"
- script.execute: script_dim_up_timer
on_release:
then:
- if:
condition:
light.is_on:
then:
- logger.log: "Physical dim_up release trigger"
- script.stop: script_dim_up_timer
- logger.log: "Script_dim_up_timer stopped"
button:
on_press:
then:
on_press:
then:
on_press:
then:
- logger.log: "Stopping timer script"
Let me also share my version, based on the excellent post of @pimw above.
What I changed:
false and it to true when the light is 1%). It is can also be controlled by a switch which is exposed to Home AssistantAn example based on my config
I use packages so you can easily change your configuration in one place, and don’t need to change it for all your similar devices.
So this is the config for one of my Shelly Dimmers
I use a fixed ip for all my ESPHome devices, so that’s why it is also included here.
substitutions:
lower_name: dimmer-zolder
ip: 192.168.2.18
max_temp: "70" # °C
dim_lenght: "10s"
restore_mode: "restore_default_off"
min_brightness: "470"
max_brightness: "1000"
leading_edge: "false"
gamma_correct: "0"
light_icon: mdi:coach-lamp
packages:
dimmer: !include packages/shelly/shelly_dimmer.yaml
This is then the configuration for the dimmer, in it I include more packages with generic config I use for all my ESPHome devices (minimal.yaml has settings like api, ota, wifi etc, basic.yaml provides sensors for uptime, wifi status, api connection status etc)
The substitutions are also added here, to act a default if they are not added above. The only one not added here is the IP address, to avoid providing the same IP twice.
# set default substitutions if not defined in config
substitutions:
name: "Shelly Dimmer 2"
lower_name: shelly-dimmer-2
max_temp: "70" # °C
dim_lenght: "10s"
gamma_correct: "0"
light_icon: mdi:lightbulb
# ESPhome generic config
esphome:
friendly_name: ${name}
project:
version: "1.0"
esp8266:
board: esp01_1m
# load packages with default settings
# see https://github.com/TheFes/HA-configuration/tree/main/esphome/packages/0_general
packages:
minimal: !include ../0_general/minimal.yaml
basic: !include ../0_general/basic.yaml
# based on the config of pimw from community post https://community.home-assistant.io/t/shelly-2-dimmer/232324/18
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 115200
light:
icon: ${light_icon}
leading_edge: ${leading_edge}
min_brightness: ${min_brightness}
max_brightness: ${max_brightness}
restore_mode: ${restore_mode}
gamma_correct: ${gamma_correct}
firmware:
version: "51.6"
update: true
# set the global for the dim action based on the brightness value
on_state:
- if:
condition:
- lambda: "return(id(dimmer).remote_values.get_brightness() == 1);"
then:
- globals.set:
value: "true"
- if:
condition:
- lambda: "return(id(dimmer).remote_values.get_brightness() < 0.013);"
then:
- globals.set:
value: "false"
- platform: ntc
calibration:
b_constant: 3350
on_value:
then:
- if:
condition:
- sensor.in_range:
above: ${max_temp}
then:
- light.turn_off:
title: Message from ${name}
data_template:
on_value_range:
then:
data_template:
resistor: 32kOhm
- platform: adc
pin: A0
# globals for dim action and light control
globals:
- id: dim_down_bool
type: bool
restore_value: true
initial_value: "true"
- id: control_light
type: bool
restore_value: true
# switches to determine light control and dim action
switch:
restore_state: false
turn_on_action:
- globals.set:
value: "true"
turn_off_action:
- globals.set:
value: "false"
lambda: |-
return id(dim_down_bool);
entity_category: config
turn_on_action:
- globals.set:
value: "true"
turn_off_action:
- globals.set:
value: "false"
lambda: |-
return id(control_light);
script:
mode: restart
then:
- delay: ${dim_lenght}
mode: restart
then:
mode: single
then:
- logger.log: "Start dimming down"
- while:
condition:
and:
- lambda: "return(id(dimmer).remote_values.get_brightness() >= 0.01);"
then:
- delay: 0.01s
- logger.log: "Dimming down stopped"
- globals.set:
value: "false"
- logger.log: "Toggled dim action to dim up"
- id: script_dim_up
mode: single
then:
- while:
condition:
and:
- lambda: "return(id(dimmer).remote_values.get_brightness() <= 0.999);"
then:
- delay: 0.01s
- logger.log: "Dimming up stopped"
- globals.set:
value: "true"
- logger.log: "Toggled dim action to dim down"
mode: single
then:
- if:
condition:
light.is_on:
then:
- light.turn_off:
else:
- light.turn_on:
binary_sensor:
- platform: gpio
pin:
number: GPIO14
mode: INPUT
internal: false
on_multi_click:
- timing:
- ON for at most 1s
- OFF for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- OFF for at least 0.2s
then:
- if:
condition:
- api.connected:
then:
- homeassistant.event:
event: esphome.button_pressed
device: ${name}
click_type: restart
button: "1"
- button.press: restart_button
- timing:
- ON for at most 1s
- ON for at most 1s
then:
device: ${name}
click_type: double
- if:
condition:
or:
- switch.is_on: control_light_active
- not:
- api.connected:
then:
- light.turn_on:
brightness: 100%
- timing:
then:
device: ${name}
click_type: short
- if:
condition:
or:
- not:
- api.connected:
then:
- timing:
then:
device: ${name}
click_type: long
- if:
condition:
or:
- not:
- api.connected:
then:
- if:
condition:
lambda: |-
then:
else:
on_release:
then:
device: ${name}
click_type: release
- if:
condition:
or:
- not:
- api.connected:
then:
- if:
condition:
light.is_on:
then:
button:
on_press:
then:
on_press:
then:
on_press:
then:
In total it looks like this in ESPHome (2 sensors are added by the Fritz!Box integration, the one to enable the internet connection, and the device_tracker)
this post is already 1,5 years old. Is this still acutal? Or did you improve something in the meantime.
I am still on the original firmware for most of my shelly dimmers but I have one flashed with tasmota. Cool thin is, the delay from the phyiscal button is gone with tasmota, but I am still not a big fan of tasmota. I would like to try esphome because I already have other devices running this.
Can you confirm if the physical delay is also gone with esphome?
