Shelly 2PM energy
I use Shelly’s QNSW-002P16 type relay and the performance measurement is not good.
The total consumption is 0. One device also has the following results. The graph shows it well. It has a 5 V power supply
It says 13 w consumption, in principle it should be around 30-40 w, and long-lighting led burners. On an industrial power supply
kép
Did you manage to find the solution for this?
I have the exact same with 1 of the outputs of the 2PM. I have a dishwasher connected to that one and it shows the same behavior.
The other output with a Quooker connected is showing normal behavior.
unfortunately not
