I have a Shelly 2PM gen 4 device. Unlike earlier generation Shelly devices, the Gen 4 devices have Zigbee connectivity in addition to WiFi. I have the 2PM device connected to HA both via Zigbee (Zigbee2MQTT) and via WiFi.
One feature of Shelly devices that I really like and use a lot, is that one can detach the inputs. This means that the state of the output does not directly change when the input changes state. This is a really powerful concept. I use it to keep my (Zigbee) smart bulbs powered all the time, but still be able to control them via the normal light switches. With a Shelly 2PM I can measure their usage as a bonus, and I’m still able to switch them, which comes in handy whenever I need to (re)pair them to the Zigbee network.
As said, I have connected my new 2PM gen 4 device both via Zigbee and via WiFi. However, there is a difference between the two integrations. In the WiFi version, I see both the outputs (as switch devices) and input (as sensors) in HA.The Zigbee-connected version shows up as MQTT device (since I’m using Zigbe2MQTT), but only shows two switches for the outputs. I can’t see the sensors for the inputs.
Did someone manage to get the inputs show up as sensors, just as it works when connected over WiFi?
