solved paypal.me
it seems to be not work at the beginning, but this was because iÂŽve not exported eny energy.
In the end of a day i have 4 different stats.
offical power meter from house (10kw)
Shelly (11,3kw)
HomeAssitant (11,2)
Your Script (8,9kw)
So what should i trust? I guess this is due to the update cycle of the values. guess nothing is accurate like the official power meter?
Is there any way for a step by step explanation on how to set this up?
Unfortunately I am not yet so fit in HA.
That would be very nice!
Hey James,
could you please see my last post, I really need urgend help with that!
You might need to do some googling and reading to understand how HA works, this is a bit advanced.
Essentially you need to add the templates to your configuration.yaml and restart Homeassistant.
This will give you the energy entities you can add to your HA Dashboard and use to configure the Energy Dashboard. If you are unsure how to do this google it there are many examples.
Thanks a lot!
I got it so far, the only thing is why it did between 9-10 this strange thing. How could it be to export more as prduced? Even we started working and must have used 90-95% of the Produced Energy.
Thats the Script, just change the names.
platform: template
sensors:Template sensor for values of power import (active_power > 0)
power_import:
friendly_name: âPower Importâ
unit_of_measurement: âWâ
value_template: >-
{% if (states(âsensor.hausverbauch_channel_a_powerâ)|float + states(âsensor.hausverbauch_channel_c_powerâ)|float + states(âsensor.hausverbauch_channel_c_powerâ)|float) > 0 %}
{{ states(âsensor.hausverbauch_channel_a_powerâ)|float + states(âsensor.hausverbauch_channel_c_powerâ)|float + states(âsensor.hausverbauch_channel_c_powerâ)|float }}
{% else %}
{{ 0 }}
{% endif %}
availability_template: â{{
[ states(âsensor.hausverbauch_channel_a_powerâ),
states(âsensor.hausverbauch_channel_c_powerâ),
] | map(âis_numberâ) | min
}}âTemplate sensor for values of power export (active_power < 0)
power_export:
friendly_name: âPower Exportâ
value_template: >-
{% if (states(âsensor.hausverbauch_channel_a_powerâ)|float + states(âsensor.hausverbauch_channel_c_powerâ)|float + states(âsensor.hausverbauch_channel_c_powerâ)|float) < 0 %}
{{ (states(âsensor.hausverbauch_channel_a_powerâ)|float + states(âsensor.hausverbauch_channel_c_powerâ)|float + states(âsensor.hausverbauch_channel_c_powerâ)|float) * -1 }}
{% else %}
{{ 0 }}
{% endif %}
}}âTemplate sensor for values of power consumption
power_consumption:
friendly_name: âPower Consumptionâ
value_template: >-
{% if (states(âsensor.power_exportâ)|float(0)) > 0 and (states(âsensor.solar_powerâ)|float(0) - states(âsensor.power_exportâ)|float(0)) < 0 %}
{% elif (states(âsensor.power_exportâ)|float(0)) > 0 and (states(âsensor.solar_powerâ)|float(0) - states(âsensor.power_exportâ)|float(0)) > 0 %}
{{ (states(âsensor.solar_powerâ)|float(0)) - states(âsensor.power_exportâ)|float(0) }}
{% else %}
{{ states(âsensor.power_importâ)|float(0) + states(âsensor.solar_powerâ)|float(0) }}
{% endif %}
Sensor for Riemann sum of energy import (W â Wh)
- platform: integration
source: sensor.power_import
unit_prefix: k
round: 1
method: left
Sensor for Riemann sum of energy export (W â Wh)
source: sensor.power_export
unit_prefix: k
round: 1
method: left
Sensor for Riemann sum of energy consumption (W â Wh)
source: sensor.power_consumption
unit_prefix: k
round: 1
method: left
utility_meter:
energy_import_daily:
source: sensor.energy_import_sum
name: Energy Import Daily
cycle: daily
energy_import_monthly:
name: Energy Import Monthly
cycle: monthly
energy_export_daily:
source: sensor.energy_export_sum
name: Energy Export Daily
cycle: daily
energy_export_monthly:
name: Energy Export Monthly
cycle: monthly
energy_consumption_daily:
source: sensor.energy_consumption_sum
name: Energy Consumption Daily
cycle: daily
energy_consumption_monthly:
name: Energy Consumption Monthly
cycle: monthly
Why are you adding this twice sensor.hausverbauch_channel_c_power ?
Is there no sensor.hausverbauch_channel_b_power?
If you only have two phases, just remove the middle duplicated entry.
Ah, got it, did a mistake while rename it.
Shelly 3EM templates for 3-phase Net Import, Export and Consumption(if you have solar generation details)
This uses the shelly instantaneous power sensors to achieve the best possible accuracy.
Shelly Sensors are sensor.hausverbauch_channel_a_power, sensor.hausverbauch_channel_b_power, sensor.hausverbauch_channel_c_power for the three phases
Solar generation in W is used to calculate consumption via sensor.solar_power
V1.0 Initial release by Uksa007
V1.1 add float(0) to Consumption template to stop log warnings.
V1.2 add Friendly names to Utility Meter sensors
V1.3 remove negative spikes from power consumption due to different update timing of solar sensor
platform: template
power_import:
value_template: >-
{% if (states(âsensor.hausverbauch_channel_a_powerâ)|float + states(âsensor.hausverbauch_channel_b_powerâ)|float + states(âsensor.hausverbauch_channel_c_powerâ)|float) > 0 %}
{{ states(âsensor.hausverbauch_channel_a_powerâ)|float + states(âsensor.hausverbauch_channel_b_powerâ)|float + states(âsensor.hausverbauch_channel_c_powerâ)|float }}
{% else %}
{{ 0 }}
{% endif %}
states(âsensor.hausverbauch_channel_b_powerâ),
power_export:
value_template: >-
{% if (states(âsensor.hausverbauch_channel_a_powerâ)|float + states(âsensor.hausverbauch_channel_b_powerâ)|float + states(âsensor.hausverbauch_channel_c_powerâ)|float) < 0 %}
{{ (states(âsensor.hausverbauch_channel_a_powerâ)|float + states(âsensor.hausverbauch_channel_b_powerâ)|float + states(âsensor.hausverbauch_channel_c_powerâ)|float) * -1 }}
{% else %}
{{ 0 }}
{% endif %}
power_consumption:
value_template: >-
{% else %}
{% endif %}
what entities do i neet for the Energy meter in HA.
- network consumption
- back to the electricity grid
Looks better, you will need to restart Home Assistant for it to take effect.
Consumption and Returned to grid, Import and Export in my scripts, see pic in post of the config:
thx for that.
you say âYou need to supply your own daily solar generation data from your inverter for Solar Production.â. I have a shely em1 for the Solar. How can i create the âdailyâ data for the Solar?
Do i need a new Sensor?
i have only entities of Power (W) ,Energy (kWh) and energy Returned (kWh)
edit:
i create a sensor like this:
power_solargen:
friendly_name: "Power Solar Generation"
unit_of_measurement: 'W'
value_template: >-
{% if (states('sensor.pv_600_wp_channel_1_power')|float(0)) < 0 %}
{% else %}
{{ 0 }}
{% endif %}
source: sensor.power_solargen
unit_prefix: k
round: 1
method: left
energy_solargen_daily:
source: sensor.energy_solargen_sum
name: Energy solargen Daily
cycle: daily
but it doesnât work. No value at power solar generation.
on my shelly em 1. The Power Value is negative (W). Is that a Problem?
where is my mystake?
Thanks James, it is working (after the red Line), tested also Battery Charger
Last Question I have is, if and how could it be possible to integrade a Powergauge combined with all Phases (Net), like on the second Picture (Haushalt Energie, which is read with a Pulsmeter but dosent count if it is negative)
This is probably what you are looking for:
source: sensor.pv_600_wp_channel_1_power
unit_prefix: k
round: 1
method: left
cycle: daily
Create a gauge and use sensor.power_import, that with give you the Net import of all the phases.
thx a lot.
Now it works perfekt.
The negative Power from the shelly em 1 is not a Problem? If yes,i can Turn over the power clamp.
edit:
the âenergy_solargen_dailyâ is after 3 Hours still empty. 0 kWh.
"energy solargen sum is â-1,8kWhâ.
could it be that it takes more time for something to appear here or have I forgotten something else?
No sensor needed right�
edit2:
i add on the utility meter ânet_consumption: trueâ. This works for me.
But this one doest give me a Value
So at leat it works if the House Consumption is positiv (Gauge was set to -500 and +5000) but if itâs not that easy, letâs forget it
more important would be what and where I need to add to the YAML for a second solar array.
Background is that I have a battery, because I charge via a plug S on L2.
However, I can not specify a second sensor to discharge.
Since I still have a plug left I would want to make the feed into the house network simply via another Shelly plug.
Solar 1 is sensor.solar_power (L3)
Solar 2 schould be sensor.solar_power2 on L2
is this possible?
If you are metering the mains with the Shelly 3EM, you already have all of net import and export(this will include all of the solar on both phases) with my templates.
I believe HA usually wants Solar positive, at least that how mine is from my inverters integration, not sure if works correctly if negative.
