Please see my templates below to calculate Net Metering correctly for the Shelly 3EM with 3-phase and solar(single or 3-phase), as used in Australia and many other countries.
This uses the shelly instantaneous power sensors to achieve the best possible accuracy, as the counters are updated approx. every second.
The energy import and export daily sensors can then be used in the HA new Energy Dashboard.
Setup your Shelly 3EM using the core integration.
Tested and working on HA 2022.2.3 Shelly FW 20211109-131251/v1.11.7-g682a0db
Copy and paste the templates into your configuration.yaml, restart homeassistant
Configure the energy dashboard as per the photo in post 9 Energy dashboard config
Let me know if this helps you out!
If you find this useful please Buy Me A Beer, thanks!
# Shelly 3EM templates for 3-phase Net Import, Export and Consumption(if you have solar generation details)
# This uses the shelly instantaneous power sensors to achieve the best possible accuracy.
# Shelly Sensors are sensor.l1_power, sensor.l2_power, sensor.l3_power for the three phases
# Solar generation in W is used to calculate consumption via sensor.power_solargen
# V1.0 Initial release by Uksa007
# V1.1 add float(0) to Consumption template to stop log warnings.
# V1.2 add Friendly names to Utility Meter sensors
# V1.3 remove negative spikes from power consumption due to different update timing of solar sensor
# V1.4 change round: 2 for small value users.
sensors:
# Template sensor for values of power import (active_power > 0)
power_import:
friendly_name: "Power Import"
unit_of_measurement: 'W'
value_template: >-
{% if (states('sensor.l1_power')|float + states('sensor.l2_power')|float + states('sensor.l3_power')|float) > 0 %}
{{ states('sensor.l1_power')|float + states('sensor.l2_power')|float + states('sensor.l3_power')|float }}
{% else %}
{{ 0 }}
{% endif %}
availability_template: "{{
[ states('sensor.l1_power'),
states('sensor.l2_power'),
] | map('is_number') | min
# Template sensor for values of power export (active_power < 0)
power_export:
friendly_name: "Power Export"
value_template: >-
{% if (states('sensor.l1_power')|float + states('sensor.l2_power')|float + states('sensor.l3_power')|float) < 0 %}
{{ (states('sensor.l1_power')|float + states('sensor.l2_power')|float + states('sensor.l3_power')|float) * -1 }}
{% else %}
{{ 0 }}
{% endif %}
# Template sensor for values of power consumption
power_consumption:
friendly_name: "Power Consumption"
value_template: >-
{% if (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) < 0 %}
{% elif (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) > 0 %}
{{ (states('sensor.power_solargen')|float(0)) - states('sensor.power_export')|float(0) }}
{% else %}
{{ states('sensor.power_import')|float(0) + states('sensor.power_solargen')|float(0) }}
{% endif %}
# Sensor for Riemann sum of energy import (W -> Wh)
- platform: integration
source: sensor.power_import
unit_prefix: k
round: 2
method: left
# Sensor for Riemann sum of energy export (W -> Wh)
source: sensor.power_export
unit_prefix: k
round: 2
method: left
# Sensor for Riemann sum of energy consumption (W -> Wh)
source: sensor.power_consumption
unit_prefix: k
round: 2
method: left
utility_meter:
energy_import_daily:
source: sensor.energy_import_sum
name: Energy Import Daily
cycle: daily
energy_import_monthly:
name: Energy Import Monthly
cycle: monthly
energy_export_daily:
source: sensor.energy_export_sum
name: Energy Export Daily
cycle: daily
energy_export_monthly:
name: Energy Export Monthly
cycle: monthly
energy_consumption_daily:
source: sensor.energy_consumption_sum
name: Energy Consumption Daily
cycle: daily
energy_consumption_monthly:
name: Energy Consumption Monthly
cycle: monthly
Great work, this is an ongoing issue, so I’ll implement your templates.
I have resisted the Riemann sum integration of instant power (W) to calculate energy (Wh), as the shelly also measures energy directly (Wh) without calculation, but as you say it doesn’t handle the net metering correctly.
So I wonder which will be more ‘accurate’ and reflect the actual electricity provider measurement using their meter?
I have compared with my Electricity provider smart meter data daily totals for usage and solar feedin, using the templates energy_import_daily and energy_export_daily.
It’s better than I expected, it’s about 1% different so that’s pretty good!, given there would also be Shelly measurement accuracy in play.
I presume it is faster as it doesn’t have to lookup the same sensors multiple times. Also reduces errors when entering yaml as it is simpler/ shorter as you don’t need to duplicate sensors entries.
But as with most things there are many ways to achieve the same outcome.
Use Energy Import Daily for Grid Consumption and Energy Export Daily for Returned to grid.
You need to supply your own daily solar generation data from your inverter for Solar Production.
i’m having trouble with getting the integrations up and running.
I copied the above sensor: section into my sensors.yaml (which is referenced in configuration.yaml) and the utility_meter: section directly into my configuration.yaml. I also changed the shelly 3em entities according to my config, of course.
Now while i’m seeing all the new entities successfully created, the energy_*_sum integrations are not updated - even though the “Power *” templates are showing the correct values.
Looks ok, does it work as expected?
I also have two solar inverters and I have a template that adds the two together so I can see my total solar generation.
# Template sensor for values of energy Solar generation (solar_power > 0)
power_solargen:
friendly_name: "Power Solar Generation"
value_template: >-
{% if (states('sensor.pv_power')|float(0) + states('sensor.pv_power_2')|float(0)) > 0 %}
{{ (states('sensor.pv_power')|float(0) + states('sensor.pv_power_2')|float(0)) }}
{% else %}
{{ 0 }}
{% endif %}
