Shelly Addon - control shelly temperature automation
Hi, I use Shelly 1 with the Temperature add-on for my underfloor heating.
I can also see the values (humidity and temperature) in HA.
You can activate temperature control in Shelly itself.
Is there a way to change these values via HA?
Background: If HA fails, the Shelly automatic system simply continues to run.
Theoretically this is possible, but then you first need the appropriate HTTP request.
So you have to deal with it first, once you have it you can send it to HA’s Shelly.
And about your background: HA does not normally fail! But if something does happen, you can also reactivate the Temp action in the Shelly.
