Shelly BLU RC Button 4 - Connection problems
Hi, I am having connection problems with the new Shelly BLU Button RC 4.
It was discovered and added without any problem, but Home Assistant recognises the button presses very unreliably, perhaps only every fifteenth or twentieth button press is recognised.
My setup ist Home Assistant Core in a VM on Proxmox and Amazon Bluetooth 5.3 Adapter.
This works perfectly with several BLU Button1 buttons and other Shelly BLU devices.
The Shelly Smart Control and BLE Debug app register every button press of the BLU RC Button 4, so it seems the problem is in the Home Assistant or BTHome.
Home Assistant recognise it as “BLU Button1”, is that ok?
What I have tried so far:
RC Button 4:
  • Reset
  • Reflashed latest firmware
Home Assistant:
  • Restart
  • Delete and added Button again
What is acting as your Bluetooth gateway in HA?
Is this close to the BLU
Is the Shelly, which acts as a BLE observer in the Shelly app, also configured as a gateway in HA?
My bluetooth gateway in HA is the Amazon Bluetooth 5.3 Adapter.
I don’t use a Shelly as a BLE observer in HA because my flat is quite small and the adapter’s antenna reaches everywhere. And I thought it would be easier to set up.
It also make no difference if the BLU button is next to the atennea or few meters away.
My BTHome only shows the battery sensor. i cannot see the buttons or run any automations. any ideas?
Is this supposed to work in HA over BT? I’m asking because switchbot button needs to be paired so it does not work with HA.
Unfortunately many of the USB bluetooth sticks are built to work on very specific OS/Driver/HW combination. I went trough so many bluetooth sticks before landing to a golden-standard which just works with Linux and with every port in my machines.
You will most likely want a device with RTL8761 chipset.
This will also have the correct chipset but reliability for longer distance is really bad https://www.amazon.de/dp/B0B2737HPS?ref=ppx_yo2ov_dt_b_fed_asin_title
Go with the EDUP with external antenna (or any other with RTL8761 chipset and external antenna)
(oh, I just noticed that the adapter you have has the same chipset, there were some discussion about the firmware being different as your device is stated to support bluetooth 5.3, not 5.1 where the chipset was originally made?)
And bare in mind that many usb3.0 ports can cause interference with USB sticks, so you can experiment with usb extension cables to both get rid of noise near the port at host machine and to better placement of the antenna.
Make sure your 4 Button device is “paired”. I had the same issue/question as you but after futzing with it (use Shelly App to update firmware/pay attention to button pressing sequence requested from the App), then the device came up in BTHome integration and every button was addressable/programmable.
Hi Hount,
Thanks for the suggestion!
I ended up returning the RC Button because I couldn’t get it to work. Now I’ve got a BLU Wall Switch 4—and had the same issue. :joy:
Turns out the fix was simple: I just had to enable “Passive Scanning” in the Bluetooth adapter settings in Home Assistant. Now it works perfectly!
Links for anyone interested:
Thanks for the help! :slight_smile:
Unfortunately, this setting broke the Bluetooth connection to my Govee H5075 hygrometers. I tried to reproduce this multiple times and found that I can decide between getting the button presses from the Shelly (passive scanning on) or getting the values from my hygrometers (passive scanning off).
How can I fix this?
Do I need a different or an additional Bluetooth adapter?
Thanks for help :slight_smile:
