Shelly BLU RC Button 4 US ZB
I created a blueprint for using Shelly BLU RC Button 4 US ZB. When connecting on zigbee it didn’t bring the buttons in, so I created a blueprint to make it easier, Here it is: Full disclosure, I don’t code so gemini did the heavy lifting.
blueprint:
  name: Shelly 4-Button Remote (ZHA)
  description: Automate your Shelly 4-Button remote using ZHA events.
  domain: automation
  input:
    remote:
      description: Select the Shelly Wall Switch to use
      selector:
        device:
          integration: zha
          manufacturer: Shelly
    # --- BUTTON 1 INPUTS ---
    button_1_single:
      name: Button 1 - Single Press
      default: []
      selector:
        action: {}
    button_1_double:
      name: Button 1 - Double Press
      default: []
      selector:
        action: {}
    button_1_long:
      name: Button 1 - Long Press
      default: []
      selector:
        action: {}
    button_1_release:
      name: Button 1 - Release
      default: []
      selector:
        action: {}
    # --- BUTTON 2 INPUTS ---
    button_2_single:
      name: Button 2 - Single Press
      default: []
      selector:
        action: {}
    button_2_double:
      name: Button 2 - Double Press
      default: []
      selector:
        action: {}
    button_2_long:
      name: Button 2 - Long Press
      default: []
      selector:
        action: {}
    button_2_release:
      name: Button 2 - Release
      default: []
      selector:
        action: {}
    # --- BUTTON 3 INPUTS ---
    button_3_single:
      name: Button 3 - Single Press
      default: []
      selector:
        action: {}
    button_3_double:
      name: Button 3 - Double Press
      default: []
      selector:
        action: {}
    button_3_long:
      name: Button 3 - Long Press
      default: []
      selector:
        action: {}
    button_3_release:
      name: Button 3 - Release
      default: []
      selector:
        action: {}
    # --- BUTTON 4 INPUTS ---
    button_4_single:
      name: Button 4 - Single Press
      default: []
      selector:
        action: {}
    button_4_double:
      name: Button 4 - Double Press
      default: []
      selector:
        action: {}
    button_4_long:
      name: Button 4 - Long Press
      default: []
      selector:
        action: {}
    button_4_release:
      name: Button 4 - Release
      default: []
      selector:
        action: {}
mode: restart
max_exceeded: silent
  - platform: event
    event_type: zha_event
    event_data:
      device_id: !input remote
  - variables:
      command: "{{ trigger.event.data.command }}"
      args: "{{ trigger.event.data.args }}"
      endpoint: "{{ trigger.event.data.endpoint_id }}"
  - choose:
      # --- BUTTON 1 LOGIC ---
      - conditions:
          - "{{ endpoint == 1 }}"
          - "{{ command == 'on' }}"
        sequence: !input button_1_single
      - conditions:
          - "{{ command == 'recall' }}"
          - "{{ args == [1, 1, 10] }}"
        sequence: !input button_1_double
      - conditions:
          - "{{ command == 'step' }}"
          - "{{ args == [0, 20, 10, 0, 0] }}"
        sequence: !input button_1_long
      - conditions:
          - "{{ args == [1, 11, 10] }}"
        sequence: !input button_1_release
      # --- BUTTON 2 LOGIC ---
      - conditions:
          - "{{ command == 'off' }}"
        sequence: !input button_2_single
      - conditions:
          - "{{ args == [2, 1, 10] }}"
        sequence: !input button_2_double
      - conditions:
          - "{{ args == [1, 20, 10, 0, 0] }}"
        sequence: !input button_2_long
      - conditions:
          - "{{ args == [2, 11, 10] }}"
        sequence: !input button_2_release
      # --- BUTTON 3 LOGIC ---
      - conditions:
          - "{{ endpoint == 2 }}"
        sequence: !input button_3_single
      - conditions:
          - "{{ args == [3, 1, 10] }}"
        sequence: !input button_3_double
      - conditions:
        sequence: !input button_3_long
      - conditions:
          - "{{ args == [3, 11, 10] }}"
        sequence: !input button_3_release
      # --- BUTTON 4 LOGIC ---
      - conditions:
        sequence: !input button_4_single
      - conditions:
          - "{{ args == [4, 1, 10] }}"
        sequence: !input button_4_double
      - conditions:
        sequence: !input button_4_long
      - conditions:
          - "{{ args == [4, 11, 10] }}"
        sequence: !input button_4_release
Hello Chad,
Thanks for contributing to the community with a new Blueprint.
I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
I’m am not really sure how to do that. I can’t figure out where I get the url from. I went to the blueprint in my HA, and pressed m, but there is no matching mylink found.
I gave you a link. Click it, then add
https://community.home-assistant.io/t/shelly-blu-rc-button-4-us-zb/978816
Then it creates a link for you. Copy the markdown url and paste it in your top post if it lets you edit it.
Like this:
Thanks, it isn’t letting me edit the post (only the script) so your link will have to do.
If you do a bit more interaction with the forum, it will let you update it. Access is based on Forum experience to deter spammers.
You need to be a trust level ‘member’ to edit a post. Understanding Discourse Trust Levels
And yes, I won’t delete my link unless you are eventually able to edit yours.
Thank you for this. I was just beginning to get frustrated with making this work with my HA. So far I haven’t been able to get any long-press actions to work. Do they work for you?
I didn’t test it until you mentioned it. I am having some problems with it as well. I will look into it and see if i can figure something out there.
I had some trouble with the long presses too. AI Disclosure: Claude and I took a couple passes at this. It took a few rounds of testing, but I think my take away is that there’s not a true release event. I took out the step events since those were causing the automation to restart every time, and mapped recall to long press.
Seems to be mostly working for me now, but let me know if ya’ll see other bugs.
Here’s my version:
Or import manually: Shelly BLU RC Button 4 ZHA Blueprint for Home Assistant (with long press endpoint fix) · GitHub
Thank you so much, this works perfectly.
