Here is a configuration that works with Shelly Color bulb firmware v1.14.0 and Home Assistant v2023.10.1.
mqtt:
- light:
name: "Office light RGB"
schema: template
qos: 1
max_mireds: 333
min_mireds: 154
# replace <deviceid> with an actual device ID
state_topic: "shellies/shellycolorbulb-<deviceid>/color/0/status"
command_topic: "shellies/shellycolorbulb-<deviceid>/0/set"
brightness_template: "{{ value_json.brightness | float | multiply(2.55) | round(0) }}"
color_temp_template: "{{ 1000000 | multiply(1/(value_json.temp | float)) | round(0) }}"
command_off_template: '{"effect": 0,"turn":"off"}'
command_on_template: >-
"turn": "on",
{%- if red is defined and green is defined and blue is defined -%}
"mode": "color",
"red": {{ red }},
"green": {{ green }},
"blue": {{ blue }},
{%- endif -%}
{%- if brightness is defined -%}
"gain": {{brightness | float | multiply(0.3922) | round(0)}},
"brightness": {{brightness | float | multiply(0.3922) | round(0)}},
{%- endif -%}
{%- if effect is defined -%}
{%- if effect == 'Meteor Shower' -%}
"effect": 1,
{%- elif effect == 'Gradual Change' -%}
"effect": 2,
{%- elif effect == 'Breath' -%}
"effect": 3,
{%- elif effect == 'Flash' -%}
"effect": 4,
{%- elif effect == 'On/Off Gradual' -%}
"effect": 5,
{%- elif effect == 'Red/Green Change' -%}
"effect": 6,
{%- else -%}
"effect": 0,
{%- endif -%}
{%- else -%}
"effect": 0,
{%- endif -%}
{% if color_temp is defined %}
"mode": "white",
"temp":{{ (1/(color_temp | float)) | multiply(1000000) | round(0) }},
{% endif %}
red_template: "{{ value_json.red }}"
green_template: "{{ value_json.green }}"
blue_template: "{{ value_json.blue }}"
effect_template: "{{ value_json.effect }}"
The following syntax is deprecated and does not work:
light:
- platform: mqtt
If I specified state_template in this form, the state of the bulb was not reported to Home Assistant. Everything works after removing it.
state_template: "{% if value_json.ison %}on{% else %}off{% endif %}"
Inspired by MQTT Config for Shelly Duo Light Bulb - Share your Projects! - Home Assistant Community.
