Shelly 2.5 in roller shutter mode has stopped working in HomeKit. It only allows fully open or fully closed. When trying to set cover position through percentage, you can hear the Shelly relay clicking multiple times, but no cover movement. Control through Home Assistant works fine. Things I’ve tried, based on other people’s experiences:
It happens with both native Shelly integration and ShellyForHASS custom component. I have tried creating a new Homekit hub for each cover, removing and recreating, deleting the integration and restarting, but nothing seems to work. Any advice? Thanks!
Help me understand, if it’s working in Home Assistant, but not working in Apple’s Homekit application, why did you post your question on the Home Assistant forum instead of Apple support forums?
