2019-06-06 08:53:05 ERROR (MainThread) [homeassistant.setup] Error during setup of component shelly
File “/config/custom_components/shelly/init.py”, line 133, in setup
from .pyShelly import pyShelly
ModuleNotFoundError: No module named ‘custom_components.shelly.pyShelly’
File “/usr/src/homeassistant/homeassistant/setup.py”, line 156, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/config/custom_components/shelly/init.py”, line 136, in setup
from pyShelly import pyShelly
ModuleNotFoundError: No module named ‘pyShelly’
2019-06-06 08:53:07 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 357, in _async_add_entity
raise HomeAssistantError(msg)
2019-06-06 08:53:09 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
homeassistant.exceptions.HomeAssistantError: Entity id already exists: switch.pihole_switch
2019-06-06 08:53:09 ERROR (MainThread) [homeassistant.setup] Error during setup of component your_domain_name
I think you need to share the custom_component to do any debugging. For my own custom_component, it is likely that the user did not have the manifest.json file. This version of Hassio has a breaking change that likely requires reinstallation of all requirements. Do you have a manifest.json file with the correct requirement in it?
Hi, I notices the shelly is offline also on his app. The shelly is inside a wall box, will be a pain to take it out.
Tryed to reset it:is it turning On-Off-On the light switch for 5 times in a row? I think I did it right and it didn’t reset … I guess the other option is to do On-Off-On 5 times the main of the house, oh man
